Now, now. He can change points faster than anybody I bet. Look in his saddle bag and I bet you will find a few soda can pull tabs or as he calls them gap gauges, along with extra points and a hand full of spark plugs.
By the way, my 04 Road King moves freely, warm or cold.
From: Southern California High Desert, here and there....
RE: Stupid question.........
ORIGINAL: DenimStreet
If my bike is off and in gear, should it be able to roll freely with the clutch engaged?
In gear with the clutch engaged, it will not roll freely, since the engine will resist spinning. But parked in neutral with clutched engaged, it will roll freely. Parked in gear, with clutch disengaged, on a wet clutch, it will roll freely once any stiction that may be present between the disengaged friction and pressure plates of the clutch is overcome.
