2011 wide glide vs 2002 softail
Old May 30, 2015 | 12:09 PM
gabo2588's Avatar
gabo2588
Default 2011 wide glide vs 2002 softail
Hi guys i need to choose between 2011 wide glide and a 2002 softail?
Which one is better? Thanks
Old May 30, 2015 | 12:21 PM
Frostbite's Avatar
Frostbite
The wide glide!
But then, I might be biased.
SPRINGER's Avatar
SPRINGER
No offense but not enough info.
Old May 30, 2015 | 04:40 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Wide Glide
Old May 30, 2015 | 05:32 PM
6 gun's Avatar
6 gun
Wide Glide
Old May 30, 2015 | 05:49 PM
Tailsfrommycrib's Avatar
Tailsfrommycrib
The wide glide is newer, has bigger engine (96CI), and a six speed transmission. So unless your a softail fan or it's a springer in mint condition you should probably go with the newer Wide glide.
Old May 30, 2015 | 06:01 PM
gabo2588's Avatar
gabo2588
Thanks guys
Old May 31, 2015 | 08:31 AM
magnum629c's Avatar
magnum629c
Hands down the 2002 is a way better bike. ..in fact i had both...first off the 5 speed is a way better Trans then that **** 6 speed that's made like junk and 2002 had a solid foundation of a crank shaft..less epa bullshit to deal with and many parts are cheaper......and power???? U do a hillside 96 inch big piston kit for 600$ some light head work and woods tw6 cams trust me u will eat any bike around even the 110....the woods tw6 with the hillside big bore kit is amazing in fact it's the fastest combo I have ever tested and I been on a **** ton of worked bikes working for a shop
Old May 31, 2015 | 08:37 AM
magnum629c's Avatar
magnum629c
And the dynas kickstands are gay there stupid design... and with the way the moter don't shake and the sexy lines and welds of the frame I'm sorry but the softail is 100% a more premium bike..***** g said it's his most proud of work over the years
Old May 31, 2015 | 08:49 AM
Tampa Fatboy's Avatar
Tampa Fatboy
I agree, first thing comes to my mind is maybe the 2002 has already had motor work done.
