Oil Pump not working?
Old Sep 20, 2015 | 10:49 PM
gslobo's Avatar
gslobo
6th Gear
My oil light stays on after I start the bike,... starting to hear a knocking noise
Old Sep 21, 2015 | 08:46 PM
gslobo's Avatar
gslobo
6th Gear
When I start the bike the oil light does not shut off.
Old Oct 17, 2015 | 05:25 PM
jaxdwg's Avatar
jaxdwg
When you take it spart again, if you haven't replaced the case cam needle brgs., you should do that too., with the Torrington/ koyo needle brgs. Check to see that the nickel sized fat oring is on correctly. I've found it easier to put the oring on the case first, grease up both the oring and the inside lip of the pump then slide it on by hand, then put the camp late on and start your four bolts and do what the manual says about tightening it up. If you put the oring in the pump first, it can screw up easily .
Old Oct 17, 2015 | 05:59 PM
nytryder's Avatar
nytryder
Is there oil in the bike? Not trying to be a smart *** just wondering.
Charles Fields
Apr 20, 2018 08:44 PM
Scrmnvtwins
Engine Mechanical Topics
Jan 26, 2015 03:29 PM
rbabos
Exhaust System Topics
Aug 5, 2008 03:40 PM
kelton3
Jul 15, 2008 06:30 PM
MikesDad
Aug 21, 2007 08:20 AM
