Rear brake question
Old Oct 15, 2015 | 03:30 AM
Next In Line's Avatar
Next In Line
Check the disc runout with a dial indicator while it is still mounted on the bike.
Old Oct 15, 2015 | 05:31 AM
Time Machine's Avatar
Time Machine
That's the first thing I would do. Plus, in a real fast stop, the back brake is not going to do that much because more of the weight shifts to the front. It's probably a coincidence.
Old Oct 15, 2015 | 06:37 AM
Next In Line
Depending how hard the stop was, the rotor could have pulled the bolts out a bit. Maybe not enough to see by eye but enough to cause problems.
Old Oct 15, 2015 | 07:01 AM
Loc_Tite's Avatar
Loc_Tite
Put it in neutral, pump the rear brake pedal, jack it up and spin the back wheel. If you hear "whish whish whish" sound and it's dragging and then spinning easy while going around you cooked your rotor.
Old Oct 15, 2015 | 10:54 PM
Douglas DeViney Sr.'s Avatar
Douglas DeViney Sr.
2nd Gear
Well...ONE very, very hard brake.. Somehow wrapped rotor. New rotor, new pads, and so far issue solved. Thank you all for your input.
Virginian
Jun 1, 2020 10:05 PM
hambone51
24
Feb 6, 2018 12:40 AM
TDG
Wheels/Tires
14
Jul 21, 2013 10:00 AM
mark10
Aug 1, 2012 02:31 AM
jawja
Sep 30, 2008 11:53 AM
