Nutty Question
Old May 8, 2007 | 12:10 AM
ChromeJunkie's Avatar
ChromeJunkie
Default Nutty Question
How do I remove the seat retention nut off the rear fender? The section on removing it in the service manual is too vague for it to make sense to me....Thanks in advance.
Rick
Old May 8, 2007 | 12:14 AM
DGlide04's Avatar
DGlide04
Default RE: Nutty Question
The nut actually mounts from under the fender and is held on by a small black plastic retaining clip that fits around the barrel of the nut that sticks through the fender. Pop off the clip and the nut will fall right out.
IF you need to replace the nut, it's really simple. The fender nut on my Dyna stripped out and it was as easy as fishing a piece of wire through the hole, from the top of the fender. When the end of the wire came out of the lower edge of the fender, slide the nut on, barrel first and then bend the wire over to hold it on, and pull it back through the fender. When the nut is through the fender, replace the clip, you're done.
Old May 8, 2007 | 12:31 AM
ChromeJunkie
Thanks DGlide...Didn't realize the clip was plastic should have known...got it out...thx again...RB
charlin1@sbcglobal.net
General Topics/Tech Tips
Oct 22, 2011 02:51 PM
Jgmurph10
Feb 24, 2010 05:32 AM
flynavy
Oct 17, 2008 05:51 PM
jcd15
Oct 13, 2007 06:54 PM
rick
May 15, 2006 02:19 PM
