Swapping Seats with ease....Help?
Old Oct 13, 2007 | 04:25 PM
flynavy's Avatar
flynavy
Default Swapping Seats with ease....Help?
Can anyone tell me where/how to get a "quick-detachable" screw that will enable me to easily swap between my 2-up and solo seat?
How do I install it?
Old Oct 13, 2007 | 04:46 PM
hk_shooter's Avatar
hk_shooter
Default RE: Swapping Seats with ease....Help?
Instead of a screw, you can get a knurled **** that you can finger tighten. It uses the stock fender nut.
Old Oct 13, 2007 | 04:51 PM
flynavy's Avatar
flynavy
I am assuming you mean the screw in the very back of the seat that holds it to the fender. I don't mind using a screw stick to put it on and off, it's the nut under the fender that worries me.
I "think" the stock solo seat has a built-into-the-fender nut, so putting that one on should be cake. The backing nut for the sundowner "I think" will just fall off after I remove the back screw...how do I get it back under the fender....?
Old Oct 13, 2007 | 04:59 PM
hk_shooter's Avatar
hk_shooter
There is a C-Clip that holds it to the fender. Fish a piece of string down thru the hole and tie the fender nut to it. Then pull the string up and Viola, the nut should be there.Then attach the clip that holds it on the fender and you should be good to go. I keep both of the fender nuts on the fender. I usually have the 2 up seat, and the one for solo seat is my spare.
Old Oct 13, 2007 | 05:10 PM
flynavy's Avatar
flynavy
HK, I am almost with ya....I have it until you talk aboutthe c-clip. How do you put any kind of a clip on the nut after it's under the fender? If you are holding it in place with the string, how do you get a clip on it? Sorry in advance if I seem too stupid to be allowed to consume oxygen.....
Old Oct 13, 2007 | 05:33 PM
hk_shooter's Avatar
hk_shooter
No problems, flynavy. It's difficult to put into words what would be very easy in person. The C-Clip goes on the top of the fender, the nut goes in from under.
Old Oct 13, 2007 | 05:34 PM
DougsDyna's Avatar
DougsDyna
ORIGINAL: flynavy
It is a special nut with a c-clip/e-clip (whatever) that you install and leave in the fender, when not in use. A $5 part, the thumb screws generally cost about $15-20, but you can use a standard 25 cent philips.
I'll try to find you a p/n if somebody doeasn't beat me to it.
DougJ
Old Oct 13, 2007 | 05:35 PM
flynavy's Avatar
flynavy
Is it not a typical round nut? Does part of the nut itself extend thru the hole so a clip can cinch it to the fender...is that what I am missing?
Old Oct 13, 2007 | 05:38 PM
flynavy's Avatar
flynavy
My sundowner is already on the bike.
I want to be able however to take it off and put it back on when I no longer want to use the stock solo seat.
If my buddy put the sundowner on and used a c-clip, the nut should stay in place even after I back the screw out and remove it, correct?
By the way also....after I remove the sundowner, does anyone know where I can get a rubber grommet to put back in the open hole on the fender that is used only for the 2-up mount? OR any other material or trick that will cover the hole?
Old Oct 13, 2007 | 05:39 PM
hk_shooter's Avatar
hk_shooter
[sm=proof.gif] Sorry I forgot to mention the(MoCo) price factor. Hope that doesn't scare you off.
