Ethanol caused engine problems?
Old May 11, 2007 | 01:07 AM
roadkingsaddlebrooke's Avatar
Default Ethanol caused engine problems?
On the way from Tucson to Lauglin's River Run two weeks ago we fueled up with a major brand of premium just outside of Phoenix. It had 10% ethanol. About 50 miles later the bike started missing alot, no matter the speed, 75 or less. Seemed to be OK during accelleration or decelleration, but it could not hold a steady speed without serious sputtering. Thought I had a bad ECM., fact that was reinforced by Harley riders stopped at Wikieup. Managed to get to Kingman, where the Mother Rode Harley service department suggested bad fuel as a likely cause. I was a little concerened about riding down into Laughlin, where it would be over 100 degrees, and then trying to get back out with a missing engine. Decided to burn off all of the ethanol fuel, then keep putting non-ethanol based fuel in the bike. After a couple of tanks, the bike got a lot better, with just occasional misses. Runs great again now that I'm back in Tucson. So I'm thinking, no more ethanol for my bike if I can help it.
Old May 11, 2007 | 01:24 AM
Panhead_1_9_4_8's Avatar
Panhead_1_9_4_8
Default RE: Ethanol caused engine problems?
ORIGINAL: roadkingsaddlebrooke
Should be able to urn 10% just fine. I use dmnay tanks on my 06 ... only think noticed was slightly less milage. Your manuel will tell you it's ok to use 10%. Guess you may have gotten a bad tank ... but the ethanol shouldn't be the culprit.
Old May 11, 2007 | 02:06 AM
Tommy Meisel's Avatar
Tommy Meisel
You got a bad tank of fuel, but I doubt if it was the ethanol that caused it. Here in the midwest you just about cannot buy fuel without 10% ethanol, but the bikes run fine with it. A little less mileage is the only downside.
Old May 11, 2007 | 02:50 AM
oldfartjc's Avatar
oldfartjc
Since I live in the Phoenix Metro area I burn it all the time with no problems. Did you get it at a brand name station or an off brand station?
Old May 11, 2007 | 02:54 AM
dajam_fxdli's Avatar
dajam_fxdli
Run it all the time here is the NW and no problems. I do notice a drop in milage.. Must have been bad or watered down, maybe. IMHO
Old May 11, 2007 | 08:39 AM
Ram's Avatar
Ram
I agree with the bad fuel, water could have been the culpret over the ethanol.
Glad to hear its straightened out for the most part. Next time you can try some dry gas (HEET) and the situation would clear sooner. That will confirm you water suspissions.
You may want to take the tank cross over hose loose and drain off some gas, then you can see for sure that the water is out of your tank. One of the times which I had my tank off I drained off quite a bit of water out of the tank, must have been close to an ounce or so.
Even now after winter some dry gas wouldnt' hurt!
Old May 12, 2007 | 01:14 AM
Thanks for the reply; I bought Chevron at I 17 and AZ 74, where a lot of bikers stop. From the other replys, I suspect that maybe it was just one bad tank of gas, though other posts include some dissatifaction with ethanol based fuels.
Old May 12, 2007 | 01:44 AM
Thanks for the info on the water testand Heet recomendation.I hope that at over $3 pergallon that the stations aren't adding water too!
Old May 12, 2007 | 08:49 AM
Roses's Avatar
Roses
Ethanol absorbs water. That is one of the drawbacks that has prevented widespread use until now. If it has been sitting in an undergroud tank with a leak it may have had some water infused in it.
Old May 12, 2007 | 08:54 AM
kwas's Avatar
kwas
In Chicagoland, it's10% ethanol in all fuel. Cannot buy anything without it. Not an issue here.
