battery bad?
Old Feb 23, 2016 | 09:02 AM
lionsm13's Avatar
lionsm13
Originally Posted by DanHappy
Hmm... hard to change out? Mine has sounding, like the same problems. Curious if it's the problem. I do not put it on a tender in the riding season, and people say that my battery could be toast. But a 13? I am questioning it. I need to test the battery and regulator first. Then possibly this is both of toe come back cool. Thanks for the other path.
No you can access the starter fairly easily actually.
I doubt it's your battery especially if you keep it on a tender?
Old Feb 23, 2016 | 09:22 AM
DanHappy's Avatar
DanHappy
I keep it on the tender in the winter only. When I am riding daily or a couple days a week, I do not put it on a tender. Even if I can't ride for a week or two in the summer, I don't put it on the tender.
Old Feb 23, 2016 | 12:21 PM
lionsm13's Avatar
lionsm13
If I'm not riding and the bike is at home in the garage it's on the tender, irregardless of the season.
Old Feb 23, 2016 | 12:51 PM
1004ron's Avatar
1004ron
I just replaced my 4 year old battery on Saturday - battery tender had been on for two weeks, green light, and it wouldn't start.
These batteries do have a finite life, and good upkeep will ensure that you get a good service life, but it will die.
Originally Posted by 1004ron
There was no way I was going miss a ride in today's glorious weather, so got the NT off the jack stand, disconnected the battery tender, wheeled it out the garage, and when I hit the start button it engaged the starter and then the solenoid started clacking.
Shot over to my local supermarket, Meijer, and got a DieHard for $90 , installed it and went for a great ride.
DieHard are made in the USA by East Penn.
Old Feb 24, 2016 | 01:25 PM
frozensoul's Avatar
frozensoul
it was a bad fob, took the one I have never used put new battery in it and bike starts fine, new battery in the fob that I always carried with me and will not start at all, not sure what happen to it. its never been wet
Old Feb 24, 2016 | 01:51 PM
1004ron's Avatar
1004ron
Originally Posted by frozensoul
bike wont start, could battery have a bad cell even if it wont turn over but still has headlights. think I may have got tender on to late this year.
If the FOB and/or FOB battery was dead, wouldn't the security system have activated when attempting to start?
What bike is it?
Old Feb 24, 2016 | 02:11 PM
Hippie49's Avatar
Hippie49
This is the way I do it.
A good battery should have no problem maintaining a charge for a week or two.
Putting one on a tender after every ride is overkill imo.
Old Feb 24, 2016 | 03:40 PM
1004ron's Avatar
1004ron
I do the same, and have at times unintentionally left it off the tender for up to two months, and it started without a hiccup. I have the security system on mine drawing just a small amount.
Old Jul 4, 2020 | 12:51 PM
LQQK_OUT's Avatar
LQQK_OUT
Originally Posted by Brewmany
I've heard that if a battery is very depleted a tender might not be able to start charging it. I've not experienced that myself, but it's been discussed before on this forum. Not sure what the specific condition that triggers this is, but apparently it can happen.
This information is actually documented in the manual for the Battery Tender Plus.
WORKING WITH A DEAD BATTERY OR A BATTERY WITH A VERY LOW VOLTAGE:
If you try to charge a dead battery having a voltage below 3 Volts, the Battery Tender Plus charger will not start. An internal safety circuit prevents the charger from generating any output voltage unless it senses at least 3 Volts at the charger output. In this situation, the red light will continue to flash, indicating that a charge has not been initiated.
Old Jul 4, 2020 | 06:37 PM
carlgrover's Avatar
carlgrover
This thread is so old the OP could have gone though another battery by now.
carl
