Need some wiring help
Old Mar 24, 2016 | 02:13 PM
KenAdams's Avatar
KenAdams
Stage II
Default Need some wiring help
Installed a tombstone taillight from J&P and am having the following problem:
When ground is connected, all lights work except brake light.
With ground not connected, all lights work except tail light.
Any advice will be much appreciated.
Bike is a 2004 Road King deluxe.
Thanks, Ken Adams
Old Mar 24, 2016 | 02:26 PM
Halojumper's Avatar
Halojumper
Did you have to splice wire it, or did it connect into an existing harness?
Old Mar 24, 2016 | 05:01 PM
GTK's Avatar
GTK
A call to J&P tech assist line is in order.Plug and play is the only way to go.
Old Mar 24, 2016 | 05:08 PM
RANGER73's Avatar
RANGER73
Three wires, green, red, black. Red = brake, Green = run, Black = ground.
If that doesn't work, check the socket, Made in China, Charley could have been color blind.
Old Mar 24, 2016 | 05:48 PM
Vernal's Avatar
Vernal
Ken,
Make sure the correct wires were hooked to the new Tombstone wires. On your 04 Road King R/Y is the brake, BE is running light, BN right turn, V left turn and BK is ground.
Old Mar 24, 2016 | 06:09 PM
KenAdams's Avatar
KenAdams
Stage II
Thanks to all. Appreciate the help.
Old Mar 24, 2016 | 06:25 PM
Vernal's Avatar
Vernal
Let us know what you find
Old Mar 24, 2016 | 06:35 PM
TwiZted Biker's Avatar
TwiZted Biker
Those generic aftermarket tombstones didn't use a ground wire unless you rigged one they relied on frame grounding when you install it, the 2 wires coming out of the socket are just for the hi/lo on the bulb , low being taillight hi being brakes.
Old Mar 24, 2016 | 07:41 PM
Vernal's Avatar
Vernal
Sure sounds like a ground wire mix up.
Some do have a ground depends on the one he got. Look at step 7
http://www.kuryakyn.com/documents/in...-25HD-0507.pdf
http://www.kuryakyn.com/products/660...tone-taillight
Old Mar 24, 2016 | 07:47 PM
TwiZted Biker
Could be with Kury stuff , never had any of theirs come through all the old style just had 2 wires.
Bullridr
Electrical/Lighting/Alarm
Feb 23, 2016 09:40 AM
07hdsporty
Apr 15, 2015 04:26 PM
OIF II vet
Feb 5, 2013 08:14 AM
Bobbed Out
Dec 20, 2009 10:24 AM
teenagertfd
Mar 30, 2008 02:12 PM
