Odometer + ECU interface
Old Jul 2, 2016 | 12:07 PM
65Tiger's Avatar
65Tiger
Default Odometer + ECU interface
2008 Road King
How does the odometer interface with the ECU? I understand that on later bikes the odometer reading is stored in the ECU and plugging in a new speedo causes the ECU to reset the odometer.
Is this the case with a 2008
I need to change my Speedo from MPH to KPH and wonder if changing the speedometer will revert to the existing odometer reading, or use what is showing on the new speedo
Old Jul 2, 2016 | 01:36 PM
skratch's Avatar
skratch
your understanding is a little off. plugging in a new speedo does not automatically cause the ecm to reset the odo. there is a speedo that you can buy from hd that does have an interface cable that will download the mileage from the ecm, but they are not all like that.
I just replaced the speedo on the wife's bike. upgraded from the stock gauges, to the cvo gauges. I had to have the moco set the mileage on her speedo. worked out great. the mileage I picked ended up being 1 mile off the actual mileage. so, I didn't worry about the difference. also, there was a sticker on the speedo from the factory stating 'mileage reinstated'.
this particular speedo is switchable from mph to kph, and does include the data cable to upload mileage:
http://www.harley-davidson.com/store...10-70900072--1
Old Jul 2, 2016 | 01:58 PM
65Tiger's Avatar
65Tiger
So if the interface cable is not used, will the odometer reading be that of the new speedo?
Understood about HD selling me a new speedo with the correct distance preset
Old Jul 2, 2016 | 04:37 PM
skratch's Avatar
skratch
I would guess that if you didn't use the interface cable, then the speedo mileage would be zero....
darryl mcpartland
Apr 19, 2017 05:26 AM
Tedjay
Mar 9, 2016 04:09 PM
jez 1
Jul 31, 2014 02:39 PM
cookieonscooter
Jul 22, 2012 11:24 PM
Blown 331
EVO
May 23, 2008 10:46 AM
