Battery tender
Old Jul 22, 2016 | 08:19 PM
user 7172984932's Avatar
user 7172984932
Excellent video that makes it simple
Motorcycle Repair : How to Check a Motorcycle Battery - YouTube
Old Jul 22, 2016 | 09:07 PM
_Gir_'s Avatar
_Gir_
Make sure you are using the correct style of charger. On the other hand, our batteries barely made it 2-3 years without the tender.
From the 2012 Dyna/Superglide Owners Manual in the front few pages:
Old Jul 23, 2016 | 07:28 AM
cocky's Avatar
cocky
I got 8 yrs out of my last bikes HD OEM battery while always on a Tender Jr.
Old Jul 23, 2016 | 09:45 AM
Bluraven's Avatar
Bluraven
As eluded to, your problem is likely the battery.
As for the tender, I never have it connected during the riding season, but then again I generally ride a little also every week.
In the off season I still ride but here in Nebraska it can be weeks between rides.
So I use the tender all winter long.
Last OEM battery lasted about 4 years before it started showing signs of weakness.
Old Jul 23, 2016 | 12:47 PM
Astroboy's Avatar
Astroboy
When you say always. Does that mean every time you park your bike for the day, you charge the batteries? Or only when it will not be used for more than two days? I just got a battery tender my self. Wondering how often I should actually charge it.
Old Jul 23, 2016 | 01:32 PM
Brewmany's Avatar
Brewmany
The nice thing about a tender is that you can connect to the bike as frequently as you like. I plug in whenever I'm done riding for the day, assuming I'm at home. That way if I don't end up riding for several days in a row, I'm set. If you use the tender daily, you're not charging the battery so much as maintaining it. Keeping the battery as charged as possible will help it last longer, in my opinion.
I got almost nine years out of the battery for my ricer, it was an AGM type and I'm sure keeping it on the tender, especially over winter, helped me get that much life out of it.
Every time a cranking battery gets discharged and recharged it shortens it's life, especially true for running it under 12V (dead). Tender helps avoid that.
Old Jul 23, 2016 | 01:35 PM
Bluraven's Avatar
Bluraven
If I had kept my OEM battery on a tender all the time it would probably also last 8+ years.
The problem with my OEM battery after 4 years was if the bike sat idle for 3-4 days it was slow starting and my speedo/tack would reset every time I started it.
It didn't "not start" the bike.
I didn't want to get caught out on the road when it finally goes.
$100 for a new battery every 4 years is acceptable to me.
Old Jul 23, 2016 | 03:01 PM
jayc2640's Avatar
jayc2640
I just bought my bike a couple of weeks ago. When the dealer's service manager was giving me the walkthrough, he told me to ALWAYS use a tender. He said that it will increase the life of the battery by years. He went on to say that these batteries don't like to get below 12v, and it can cause problems.
Old Jul 23, 2016 | 03:38 PM
Bone Doc's Avatar
Bone Doc
Yes. When the bike gets parked for the night, it's on the tender. I live in Texas and heat is a killer of batteries. Despite this, I have only gotten about 3 years out of a battery.
If you use a tender, you shouldn't have to actually charge your battery. The bike keeps it charged when you are riding and the tender keeps it charged when you aren't.
Old Jul 23, 2016 | 04:53 PM
_Gir_'s Avatar
_Gir_
Mine is plugged in every day after I ride home from work. I use the pig tail, takes literally 5 seconds to connect it.
