Cleaning Oil Off Engine?
Old Jul 25, 2016 | 07:33 PM
Big Boz's Avatar
Big Boz
I just use dawn and a plastic scrub brush
Old Jul 25, 2016 | 07:35 PM
QC's Avatar
QC
Simple Green and a toothbrush.
Old Jul 25, 2016 | 08:19 PM
_Gir_'s Avatar
_Gir_
Are the fins aluminum? I ask because I see a lot of recommendations for Simple Green and my understanding of SG is that it's not good for aluminum.
Old Jul 25, 2016 | 08:52 PM
Tommy C's Avatar
Tommy C
I've never had an issue using a 1-1 mix of Simple Green on any aluminum surface, including polished or natural finish. I don't use it on a hot engine or let it dry before rinsing, though.
Old Jul 25, 2016 | 10:07 PM
_Gir_'s Avatar
_Gir_
Found this on the simple green website:
However, caution and common sense must be used: aluminum is a soft metal that easily corrodes with unprotected exposure to water. The aqueous-base and alkalinity of Simple Green All-Purpose Cleaner can accelerate the corrosion process. Therefore, contact times for unprotected or unpainted aluminum surfaces should be kept as brief as the job will allow - never for more than 10 minutes. Large cleaning jobs should be conducted in smaller-area stages to achieve lower contact time. Rinsing after cleaning should always be extremely thorough - paying special attention to flush out cracks and crevices to remove all Simple Green product residues. Unfinished, uncoated or unpainted aluminum cleaned with Simple Green products should receive some sort of protectant after cleaning to prevent oxidation.
Old Jul 26, 2016 | 12:58 PM
ripn's Avatar
ripn
Dawn dish soap is my preference. I have a variety of brushes (Part cleaning, tooth, car washing..) that I'll use as well.
I've used Simple Green on V8 aluminum blocks w/o issue. As stated above, SG can accelerate the oxidation process, but I believe it to be true for any chemical or fluid that is left in place too long.
Old Jul 27, 2016 | 05:57 AM
YeOldeStonecat's Avatar
YeOldeStonecat
I use carb cleaner spray or engine degreaser foam first.....blast it off with the hose good. Let dry. Can leave it that way, or if you want that nice showroom "wet look" on the engine, I coat it after with "Pig Spit" (similar to S100 but I find it lasts longer).
Old Jul 27, 2016 | 06:23 AM
Uncle G.'s Avatar
Uncle G.
Originally Posted by Astroboy
I concur. I also have black denim paint. So I only use the S100 on the engine. I never had any issues with it, despite people complaining about it, that it leaves whites spots and what not. I got mine from Amazon. A tad cheaper than the dealer.
I dilute the S100 1:1 with water, and always wet the motorcycle before applying. Also don't let it dry on the motorcycle and rinse thoroughly with plenty of water.
BobHarley#1
Feb 26, 2024 11:22 PM
flyboyron
Nov 18, 2015 02:03 PM
bullast
Engine Mechanical Topics
Nov 2, 2014 06:09 PM
pauly3
Feb 7, 2013 07:24 PM
Arizona
Oil Archive (no new posts)
Dec 27, 2006 03:54 PM
