I had read an earlier thread that talked about a garage door opener remote on your bike. Most of the methods that were used involved re-wiring and some talked of purchasing costly electronics.
Since I'm not particularly mechanical, and I'm cheap, I bought a genie mini garage door remote on ebay for $12.00 and velcroed it to the sidewall of the media compartment on the fairing. Works like a champ and took about 10 minutes.
I keep mine in that compartment also. I have an older door opener with a larger remote. It sit nicely on the bottom of the compartment.
Just installed one today. Got a remote for $12 off e-bay. Went to Radio Shack and got a push button switch for $3. Soldered 2 8"pieces of wire to the remote circuit board. Drilled a 1/4" hole through the top front of my right saddle bag andinstalled the switch from the outside and connected the remote to the switch and velcroed itinside the saddle bag. Now all I have todo is reach right back next to my saddle and push the button. Took all of 20 minutes and under $20.
I did similar.
My Bike is an '89 FLHS with the big ugly breadbox instrument cluster.
I potted a wired momentary action button in epoxy in a form depressed in clay.
double sticky taped it to my brake reservoir, then put the wired remote in a baggy to make it somewhat waterproof and placed that inside the breadbox,
Has been working fine for 5 years (1 battery change.)
I use the garage mate like I said in the earlier post but that is with my sportster. On my ultra classic I took a garage remote and soldered wires inside on the circuit boar. Then attached them to a button that I attached to my fairing. The remote itself is inside the fairing. So all I need to do do is press the button on my fairing to open and close the door
Cant remember the name of the thing I have. It replaces the front master cylinder cover. Nice unit. Pain in the *** to mount. THe bolts that came were too short and I had to wait weeks to get them from the factory. Called many times and I kept getting the, "Well, my wife left me and the company is falling apart... I will send them out today with a free t-shirt...". Never did get them. I went ot a bolt place locally and made it work. Besides that, love the piece.
It's called a hog pen garage door opener. The cheapest I've found is $103 on ebay
That's it! Nice but needs adjusted to work correctly. I had to get longer bolts and I had to add spacers between the cover and the metal base that is the opener itself. If you didnt, the cover button you push pushes down on the door button mechanism and binds it up and it does not work.
