Thoughts on the Thundermax
Old Aug 29, 2016 | 06:33 PM
Levi Weuve's Avatar
Levi Weuve
Stage IV
Default Thoughts on the Thundermax
Been looking into the thunder max auto tune and was wanting some real world experience with pros and cons. Or if there is another you would prefer. Thanks guys.
Old Aug 29, 2016 | 06:35 PM
Next In Line's Avatar
Next In Line
Works without any issue on a 124".
Old Aug 29, 2016 | 09:00 PM
nevil's Avatar
nevil
I've been running mine for 8 years and no complaints. Can't be happier with the way the bike runs. Customer support was great when needed.
A couple of weeks ago I thought I felt there was something off so I hooked the bike up to the laptop and found out one of the O2 sensors went bad. Easy fix.
I just put in a set of TTI's and through the ThunderMax I've been able to see how much more efficient they are when it comes to the auto tuning process.
Old Aug 29, 2016 | 09:42 PM
uklauren's Avatar
uklauren
Florida Crew Moderator
Not had any problems with mine so far, 1 year and 15,000 miles.
Old Aug 29, 2016 | 10:06 PM
golfblues's Avatar
golfblues
Mine has been great but make sure to pick a close map. There aren't many cam choices, mostly red shift. They told me to use the red shift 575 map for my woods 555's. Bike ran like s*** and had lots of pinging. Acceleration was very flat too. The timing was set way too high on that map some as much as 12* too high. So I picked out the red shift 525 map and it was night and day. Timing was much lower. No ping. Ran a few auto tunes and it's flawless. Mine has the older serial port connection and it's very slow to read and write. 3 beers worth.
Old Aug 29, 2016 | 10:43 PM
Levi Weuve's Avatar
Levi Weuve
Stage IV
Thanks on the input guys. My bike is currently stock motor wise with the exception of intake, v&h big radius, and the SE tuner.
I went and talked to a very reputable local shop that my dad has taken I bike to for over a decade, and was going over some build ideas. He recommended the thundermax, and said your bike would never outgrow it, no matter what you threw at it. But I am planning on a set of cams and adj push rods with some headwork next spring, so I figured I could get a little taste now.
I was also pondering the idea of going ahead and getting the cylinders bored and getting some good headwork with some oversize valves, so the cams would match, or is there a set of cams I could run with just mild head work, that could later be matched with oversize valves and overbore?
Old Aug 30, 2016 | 01:32 AM
Radsdad's Avatar
Radsdad
Why get the cylinders bored when you can go to an HD 117 for $2500. They can do the mod when they do the cams
Old Aug 30, 2016 | 06:30 AM
Loc_Tite's Avatar
Loc_Tite
I've used one for a little over a year and really like it- replaced a Power Commander V with it. I get zero decel pop, zero "gurgling", and a very smooth power band. One thing though for anyone with the '08 and down "Y pipe" header- it doesn't like that and tries to richen up the back jug constantly due to the location of the O2 sensor. It'll run like a raped ape when moving and with good exhaust flow, but it will pop a lot on decel and idle.
Old Aug 30, 2016 | 08:24 AM
RIGlide09's Avatar
RIGlide09
I have it installed on my SG. 3rd season, no issues. In my opinion, they are great if you have a lot of mods but if you have a cookie cutter setup (stage 1), a simple tuner from any mfg and a canned tune will do the job.
Old Aug 30, 2016 | 04:20 PM
mazz's Avatar
mazz
Default thundermax
my tuner is a year and a half old on a 2014 limited i had experienced a lot of starting issues which thundermax owned up to quickly but not before a 3000 mile road trip where i had to start it 4 or 5 times when hot to get rolling. To be fair they always responded quickly to email and sent new maps when i requested . they also acknowledged the starting problem and fixed it . bike runs better cooler and faster than stock and sounds better with the stage one mods. i had to bug them to get gas mileage over 30 again but they sent me new maps.
i would rather have no problems but this company fixed the issues i requested
