Pulling main fuse same as disconnecting the negative terminal?
Old Sep 19, 2016 | 08:45 PM
tlminh's Avatar
tlminh
Default Pulling main fuse same as disconnecting the negative terminal?
I've been adding some accesory lighting to the bike. Can I just pull the main fuse instead of disconnecting the battery? Any major differences?
Old Sep 19, 2016 | 08:55 PM
Imold's Avatar
Imold
Make sure nobody made any modifications if you got the bike used, seen some strange wiring done. Shouldn't be an issue, but remember the big hot wire to the starter is always hot, not fused. And finally, check connections with a voltmeter just to be sure before touching them with anything else, that's saved me some embarrassment and damage several times on various electrical things that weren't what they were supposed to be.
Old Sep 19, 2016 | 08:58 PM
almostakeeper's Avatar
almostakeeper
If your bike has a Harley alarm, turn the ignition switch on, then pull fuse.
Old Sep 19, 2016 | 10:03 PM
Tommy C's Avatar
Tommy C
You will still have 12 volts at the starter B+ terminal. If the factory manual tells you to disconnect the negative terminal just do it.
Old Sep 20, 2016 | 11:34 AM
JohnMn's Avatar
JohnMn
I'm pretty sure the manual tells us to disconnect the battery if your going to check the air in the tires!
Old Sep 20, 2016 | 11:55 AM
vizcarmb's Avatar
vizcarmb
There is a potential that pulling the fuse will create an arc while pulling it. Same goes when you disconnect the plug from a socket. I would just disconnect the battery FFS, dont be lazy and find out you become an electrical path and die.
Old Sep 20, 2016 | 12:19 PM
Iarecobra's Avatar
Iarecobra
You'll still have power up to the main fuse. Safest way to go is disconnect the negative on the battery.
Old Sep 20, 2016 | 12:30 PM
RHPAW's Avatar
RHPAW
I have a nice burnt divot in my wedding ring just from reaching in by my disconnected Shovelhead battery. Not much room in there.
Old Sep 20, 2016 | 12:48 PM
ElectraJim's Avatar
ElectraJim
Isn't that the truth.....
I had to remove the fairing cap on my bike and the first thing the manual states is, "Pull the Maxi fuse". Good grief.
Old Sep 20, 2016 | 12:49 PM
riteway's Avatar
riteway
OUCH!!!! Hope you dint spill your beer........
