Anyone ever repaired their Frogg Toggs using the smoking toad repair kit? I got my repair kit but not sure which side to glue down. One side is kinda rubbery looking and the other is like a fabric. Before anyone says to use the search here already done that and didn't find the answer.
Contains: Heat resistant patch, patch adhesive and applicator brush. Easy to Use.
Directions:
To apply the Frogg Toggs SMOKIN TOAD heat shield kit to your Frogg Toggs locate the area on your Frogg Toggs where suit may come in contact with heat. Clean and dry area first, apply adhesive to the heat shield and the rain suit and let dry 15 minutes then reapply adhesive, wait until tacky and apply heat shield to rain suit, press flat and let dry overnight.
That's the instructions that came with the kit but it still doesn't say which side of the patch to use......that's what I'm looking for. Or does it matter?
That's what I was kinda thinking. The rubbery looking side is black and the cloth looking side is like a pale yellow. I did a google search and did find one answer that said the sides are different to be better able to match the the rain suit you are patching. Don't know if that's right or wrong. I do know it's a bitch to get the burned on rain suit off the pipes. Looking to prevent that in the future and salvage my suit.
