Quick Google search will yield lots of examples of fried bikes using lithium batteries (non cell phones). I also checked with my two friends who both assured me they were not running cell phone batteries. http://forums.sohc4.net/index.php?topic=89571.0
Yuasa is a dang good battery....and it's made in PA (contrary to what the name suggests). You shoulda got dang near 5 years if not more outta that.
Year 'n a half...may wanna see if somethings causing a constant drain...else you'll just be going through various other brands and having bad luck with 'em.
I also like Big Crank, made by Dekka/East Penn...who also makes the OEM batts for Harley. Cept the Big Crank is a notch better than the base model they make for Harley. And a heck-uv-a-lot-cheaper.
I put the battery tender on as soon as I got home from work, and after a couple hours I gave it a try and she fired right up.
You're right. It shouldn't be that way. Before I buy a battery, I'll run the checks on the charging system.
And coincidentally, my multi-meter needs a battery! It's always something!
I run DEKA batteries in the Shovel. I'm only 5 miles from the plant and can pick up "seconds" at their store for a steal. The one in my bike now is on it's seventh year and has never seen a trickle charger.
I put a Yuasa GYZ20HL battery in Reaper at the beginning of the season, along with Sumax 2 gauge cables. So far, so good. She cranks over easily, and reliably.
I bought a Mighty Max battery for my RK, cost was about $75.
Direct from the factory, made in the USA.
Sorry, I can't give a history, I have not installed it yet.
