Which Battery do You Like?
Old Oct 8, 2016 | 08:41 AM
bill from tn's Avatar
bill from tn
Originally Posted by Sling Blade 14
I swear by mine too!
Best I've ever used.
http://www.batterymart.com/p-big-cra...FQpmfgod_3wCUg
Today it is $84.95 and free shipping. If you need a battery this is a great deal.
Old Oct 8, 2016 | 09:26 AM
PPBART's Avatar
PPBART
Originally Posted by squirrelsnest
I just buy the HD brand battery....I've had good luck with them.
I just recently went back to the HD battery after a Big Crank failed after just one year in service. To the best of my memory, I've always gotten at least 4-5 yrs from the HD brand.
Old Oct 8, 2016 | 09:38 AM
Bone Doc's Avatar
Bone Doc
I'm not convinced that brand has much to do with how long a battery will last. Other factors have more influence including, but not limited to, how you maintain it and where you live.
I live in Texas and it is HOT. Heat is a battery killer. My batteries average about 3 years. I've checked my charging system and did not find a problem. My battery is on a tender whenever the bike is parked. I have the same load tester auto parts stores use and check the battery periodically. You can get one from Tractor Supply for $25. If need be I will charge the battery with an actual charger (not a tender).
Battery Load Tester
I am now using Batteries Plus Bulb's batteries simply because they have a two year warranty. They're as good as any other and aren't any more expensive.
Old Oct 8, 2016 | 12:58 PM
RedNose44's Avatar
RedNose44
Battery Load Tester
AGM's are not effected by heat the way wet cell batteries are. I ran 4 batteries in my last boat in AZ (extreme heat). I was only getting a couple years out of my Interstate deep cycle's. When I switched to Odyssey they were still going strong after five years when I sold the boat. My current boat has two Odyssey's, and after 3 seasons they are as strong as new. Find a quality AGM (not Optima IMO), and they will survive the heat.
Old Oct 8, 2016 | 03:04 PM
Mike Lawless's Avatar
Mike Lawless
I tend to agree RedNose.
I've been running Odyssey in my drag car for 18 years. I'm about a year into the third one. The first one is still in service on my camper. The second one died after 7 years, but I don't think it was the fault of the battery. Due to a short in the alternator, it discharged completely, and was dead, dead, dead for several weeks. I couldn't recover it.
Here in Central California, it gets hot. Even Texas hot. We frequently have days well over 110° and 30 day stretches of well over 100°.
There's several really good suggestions on the original question, and I look seriously at the experiences people have had. Based on that, the decision is nearly as difficult as it was when I asked!
Old Oct 8, 2016 | 03:10 PM
Notgrownup's Avatar
Notgrownup
I just bought a mega crank from Battery mart... $89. I used to buy big crank but decided to try the mega.
Old Oct 8, 2016 | 04:07 PM
GREENOHAWK69's Avatar
GREENOHAWK69
The one that appears to keep my female neighbor entertained throughout the night.
Old Oct 8, 2016 | 04:26 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Batteries are funny things.
Don't ride your bike very much (thinking you'll "save" it) and the battery doesn't last very long at all.
Ride the crap out of your bike (50,000+ miles) per year and the original battery lasts 7 years or better.
Use it or lose it, I guess....
Old Oct 9, 2016 | 09:48 AM
Mike Lawless
I'd agree with that Norty.
But, I did a test on the charging system, and it puts out 14v at idle, and about 14.7 at cruise rpm. So that's good.
I did fill up with premium the other day, and it seems to start easier. So......
I'm gonna have the motor semi apart this winter doing top end work. Valve job, lifters, adjusto pushrods, etc. I think checking the starter for draw might be a good idear. As well as putting a good set of battery cables on too! Electronic ignitions are sensitive to voltage, and if the starter draws too much, there might not be enough juice left for the ignition to fire. I run into this on my drag car when the battery is low.
Compared to the motors some of you fellers run, this one should be easy to start. A bone stock 88 with less than 9-1 CR.
Old Oct 9, 2016 | 09:54 AM
'Ol dirty biker's Avatar
'Ol dirty biker
Default Odyssey
Fantastic battery's. Have Optima in all my other toys and never had a problem with any of them (don't buy factory seconds at Walmart) but they don't make bike battery's so had to use Odyssey. Was only $20 more then a traditional one. For $20 more I'm surprised anyone goes for the cheap ones, your battery isn't the place to cheap out IMHO.
