Exhaust hardware
Old Jan 31, 2017 | 05:07 PM
Redomen's Avatar
Redomen
Stage III
Default Exhaust hardware
I have an aftermarket set of pipes for my 1992 FLSTC. I'm trying to find where to buy T slot bolts for them. Anyone have an idea? I need a few that are about 1 3/4" in length. 5/16 or 3/8 diameter. Any help is appreciated.
Old Jan 31, 2017 | 09:02 PM
Yankee Dog's Avatar
Yankee Dog
Dealer probably has them.
Home depot or plumbing store carries "closet bolts" used to hold a toilet down to it's flange but you will have to cut down the length. You can get them in 1/4 or 5/16.
http://www.homedepot.com/b/Plumbing-...e/N-5yc1vZc6av
I have also seen people use carriage bolts. YD
Old Jan 31, 2017 | 09:13 PM
Redomen's Avatar
Redomen
Stage III
Thank you for the help YD���� The dealer was no help and the only ones I found online would not work.
Old Jan 31, 2017 | 10:16 PM
Labrador's Avatar
Labrador
Check Ebay. I did a quick search and found a few in different length and diameter.
Old Jan 31, 2017 | 10:24 PM
Just Dan's Avatar
Just Dan
Try McMaster Carr. They carry just about any hardware you could imagine.
https://www.mcmaster.com/
Dan
Old Feb 1, 2017 | 01:59 PM
fsae0607's Avatar
fsae0607
Would a carriage bolt work for you?
Old Feb 1, 2017 | 02:12 PM
SPRINGER's Avatar
SPRINGER
My local hardware store has a tremendous selection of nuts and bolts and that's where I go if I need something. Is there a hardware store near you that might have what you need?
Old Feb 1, 2017 | 02:43 PM
Redomen's Avatar
Redomen
Stage III
I went to Home Depot and they had no t slot bolts, and lag bolt heads were too big. I took Yankee Dogs advice and bought some 5/16-2" closet bolts from the plumbing department. They fit perfect so all I need now is to make some bushings and I will be set. Thanks for all the help brothers.
Old Feb 1, 2017 | 05:59 PM
hdbob2006's Avatar
hdbob2006
Plain old bolts with the heads ground down thinner will work.
Josh Billingsley
General Topics/Tech Tips
Mar 2, 2017 08:53 AM
emperor wurm
Oct 28, 2012 08:43 AM
ChileMike
Exhaust System Topics
Jun 2, 2010 04:09 PM
por2gezo
May 31, 2010 02:09 PM
evanstock
May 8, 2010 06:40 PM
