Stage I Upgrade - $$
Old May 31, 2007 | 12:17 PM
GeezerGlider's Avatar
GeezerGlider
Default Stage I Upgrade - $$
I just called my stealer to find out what he'd charge to do the SE breather and reflash that makes up a Stage I upgrade. He said it would be just under $350 after taxes. That sounds pretty high to me, but maybe I have an unrealistic expectation. I was kinda hoping for something more in the $200 range. Does this sound right? I really need some more power - with my wife on the back, trying to pass on the highway can be flat out dangerous due to the lack of power. What do y'all think?
Thanks in advance. GG
Old May 31, 2007 | 12:36 PM
zombie's Avatar
zombie
Default RE: Stage I Upgrade - $$
Think the SE kit runs around $90 for parts, the flash around $150 I think plus labor...
Another option, install the SE kit yourself, get a PCIII or SERT and install it yourself...pretty close to the same cost I reckon and you'll actually be ahead.
Old May 31, 2007 | 01:17 PM
SUPER01's Avatar
SUPER01
[sm=exactly.gif]
I hope you already have some other mufflers installed, otherwise changing the air cleaner will not help you much if you can't move it out the exhaust fast enough with the stock ones.
Old May 31, 2007 | 03:16 PM
Cryptoboy's Avatar
Cryptoboy
As zombie said, just for the A/C and ECM flash you're looking at $250, then you need to add labor, so the $350 isn't that far off. You'd be better off getting the Big Sucker (K&N filter, but the same look overall) and installing, getting a PCIII ($250 ish), and mapping it yourself. Then, when you upgrade the pipes, you won't have to do another flash (@$150), just have to create or download a new map for the combination of pipes and A/C.....
Old May 31, 2007 | 10:40 PM
T Tommyt's Avatar
T Tommyt
YEP
ORIGINAL: Cryptoboy
Mixter
Mar 23, 2010 12:39 PM
Delmarksman
Jun 22, 2009 06:49 AM
jwmu
Aug 29, 2007 10:20 PM
cfax
Apr 2, 2007 10:16 AM
defenderp
Exhaust System Topics
17
Feb 3, 2007 11:16 PM
