How long do you warm your engine up?
Old Apr 14, 2017 | 09:53 PM
  #41
95th 1200's Avatar
95th 1200
I'll run mine until the rear rocker is slightly warm. With the carb I have it's either on or off with the choke, and if it's not sufficiently warm it won't idle.
Old Apr 14, 2017 | 10:05 PM
  #42
sixguns's Avatar
sixguns
Originally Posted by RK4ME
Who told you that?
you can fast forward to 2:37
Old Apr 14, 2017 | 10:07 PM
  #43
dixonk's Avatar
dixonk
I just hop on and start it and ride off.
Old Apr 15, 2017 | 12:15 AM
  #44
tvon's Avatar
tvon
On my carb'd sporty here in the chilly northeast? Pull the choke, 1 minute when its below 65. Above 65, 15 seconds tops.
If you're my a**hole neighbor with the brand new EFI'd Street Bob, about 15-30 minutes every morning.
Old Apr 15, 2017 | 01:21 AM
  #45
jerryt87's Avatar
jerryt87
Originally Posted by HDMIKETN64
The Amsoil blog has a pretty interesting article on engine warm up:
http://blog.amsoil.com/why-warm-up-y...7-789426574a9d
Myself, I always let my bike run while I'm putting in my earplugs, strapping on my helmet and getting my gloves on. What say you?
Same here.
Old Apr 15, 2017 | 01:47 AM
  #46
bklynbob's Avatar
bklynbob
2 or 3 minutes in mild weather. Double that if you run forged pistons.
Old Apr 15, 2017 | 02:19 AM
  #47
2AMGuy's Avatar
2AMGuy
Community Influencer
I used to let my Shovelheads warm up a bit and then I'd take it easy on acceleration even when entering the highway.
I followed this with the earlier EVO's as I (and some others) had some gasket issues and figured this may have been a contributing factor.
With the T/C's I let them warm up a bit depending on what time of the day it is but I still go easy on the throttle for a while. If I'm leaving on a trip and leave before 8:00AM I push the bike put, start it up, put the garage door down and leave. I "chug" down my road to the county road as quietly as I can so I don't P**s off the neighbors.
Old Apr 15, 2017 | 03:03 AM
  #48
Bart van der Meulen's Avatar
Bart van der Meulen
Every engine need a 'warming up' before loaded. Because, what is 'loaded' actually?. 'Loaded" is a mechanical load on all the main bearings, caused by the combustion stroke of the engine. That means, that the lubrication of the bearing must be of sufficient pressure and penetration of lubricant in all parts of a bearing. The cold oil need to be warmed up before this is obtained. When idling this internal mechanical load is limited to a minimum, during riding away there is a higher torque and rpm needed and therefor the lubrication must be optimal before increasing the load by riding away. Therefor, 30 seconds is the minimum for 'warming up', depending on your oil basic viscosity and ambient temperature. Depending on the ambient temperature I warm up between 45 seconds and 1.5 minutes. Shorter in higher temperatures, longer in colder weather.
Old Apr 15, 2017 | 03:24 AM
  #49
'Ol dirty biker's Avatar
'Ol dirty biker
First ride of the day, 5 minutes. After that depends on the temp outside. Allways enough time for the Oil to start circulating. Reading this thread makes me wanna ask the next guy I'm about to buy a bike from. If he says he fires it up and drives away, NO DEAL
Na, haven't ya heard? It's cool to rev you bike and be a dickbag, if your neighbors don't like it they aren't American and those A-holes can just move! It's your right!
Old Apr 15, 2017 | 06:18 AM
  #50
Tileman2692's Avatar
Tileman2692
Start her up...30 seconds later hit 1st and under way. I go easy for the first 5-10 mins then normal ride
