HP for 103 engine
Old Apr 21, 2017 | 11:51 AM
aquamania's Avatar
aquamania
Stage I
Default HP for 103 engine
I recently had a stage 1 upgrade to my 2013 Heritage softail classic. SE slip ons, Arlen Ness air kit and tuner was added. The bike was dyno tuned and results were 72 HP and 96 TQ. Anybody else have similar results?
Old Apr 21, 2017 | 02:08 PM
LoneWoolf's Avatar
LoneWoolf
Welcome to the forum. What were the RPM's for your #'s?
Old Apr 21, 2017 | 07:39 PM
Bone Doc's Avatar
Bone Doc
Welcome to the forum from central Texas.
A stage I upgrade is only going to translate into a 5-10% increase in power. If you are really looking to improve the HP and TQ you have to upgrade to at least a stage II. Your numbers sound reasonable for a 103 engine with a stage I. Could they be better? Possibly. Could they be worse? Possibly. They're in the ballpark.
You have a tuner that can help enrich the AFR, cool the engine and provide a limited increase in power. It is my opinion that a dyno tune with only a stage I is not necessary. It's perfectly fine to do it and there is no harm but it is trying to get maximum power from a set up that isn't designed for maximum power. Will the money spent for a dyno tune provide such a benefit in HP and TQ over the tuner alone to justify it's cost? Not in my opinion.
After a stage II, I believe a dyno is highly recommended.
Old Apr 21, 2017 | 09:30 PM
Neggy ZRXOA 5248's Avatar
Neggy ZRXOA 5248
if you are that high on torque I'd say you were good.
you don't buy a HD for HP, it is all about torque.
you can get HP, but it is going to cost a lot of money, and you will probably kick yourself when it is done or you go to sell the bike
Old Apr 22, 2017 | 06:57 AM
Oldbow's Avatar
Oldbow
Just had my 12 ultra dynoed and it had 79 hp ,can't remember the torque. Arlen Ness big sucker after market head pipe 2-1-2, Bassani mufflers with 2" cores and Power Vision tuner. They told me it would make more power with bigger cores in mufflers but I would rather be able to listen to the radio if l want.
Old Apr 22, 2017 | 08:44 AM
114's Avatar
114
Stage I
Default How much power should I have?
Hello,
This is my first time posting so if this is the wrong area for this question, please let me know. thanks
I have an '05 ultra classic
4 1/4 bore - JE forged pistons
4" stroke - stock crank and connector rods
10.38:1 comp
T-Man590 cams - gear drive
S&S camplate, S&S oil slinger, S&S HV oil pump
beehive springs
hydro lifters
1.91 intake - manley stainless one piece
1.64 exhaust - same
63mm TB/intake
Ported/Polished
Crusher true duals
Direct Link Tuner
How much hp and torque can i expect?
prerender
Nov 19, 2020 04:58 PM
hoethree
May 20, 2015 09:43 PM
JimGnitecki
Engine Mechanical Topics
172
Feb 5, 2015 02:31 PM
Basic
Jun 10, 2011 10:42 PM
6165hd
Jul 28, 2007 11:32 PM
