Snapped element mounting stud - Help!
Old Apr 23, 2017 | 04:23 PM
Ludwig von Buzzthoven's Avatar
Default Snapped element mounting stud - Help!
While installing my OEM Stage 1 kit, I overtightened one of the element mounting studs with a torque wrench - in not sure what happened. The wrench was set correctly.
Exactly how screwed am I? Can I get this out myself, and if so, how? The stud came in the kit with red loctite already on it, so I'm thinking it's really going to be tough.
Old Apr 23, 2017 | 05:00 PM
ROCKOUT Rocker Products
Sponsor
If the holes go all the way through your best bet is to take the plate off & drill it out from the back side. If not, drill a slightly smaller than the bolt hole & use an easy out.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Apr 23, 2017 | 05:19 PM
Thanks for reply... I don't think the holes go all the way through. Unfortunately, I've never used an Easy Out (I'm normally really, really careful about NOT messing up like this).
Old Apr 23, 2017 | 05:22 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Here is a trick that has worked well for me in the past.
Buy a GOOD quality left hand drill bit. Put your drill in reverse and it will twist it right out. If not try an easy out.
Old Apr 23, 2017 | 05:23 PM
Uncle Larry's Avatar
Uncle Larry
If you're uneasy about repairing it ... pull the plate off and take it by a local ( machine ) shop ... they'll be glad to drill it out ... then use a Timesert ( http://www.timesert.com/ ) or whatever they recommend to repair it ( if it needs to be repaired ) They may be able to "renew" the hole and threads without it.
Old Apr 23, 2017 | 05:27 PM
TSheff's Avatar
TSheff
Centerpunch broken bolt - stuff a rag in the inlet - drill - Easy-out - chase threads to make sure they weren't a problem, put it back together with a new bolt.. Don't forget to remove the rag.
If you have the tools and parts 10 - 15 minute job.
Old Apr 23, 2017 | 06:15 PM
Thanks guys! I took the plate off, and I'll try and get the bolt out. Worst scenario: I have to buy a new backing plate and a bolt.
TwiZted Biker's Avatar
TwiZted Biker
_____
This and use a pencil torch to heat up the boss a bit when you drill the bolt, it may just spin the bolt out when the loctite gives. Left hand drill bit if the hole doesn't go through.
Old Apr 23, 2017 | 06:18 PM
LiiT's Avatar
LiiT
DanDman
Engine Mechanical Topics
Feb 25, 2019 04:44 PM
springers4ever
18
Jan 17, 2018 05:35 PM
tkuligowski
General Topics/Tech Tips
Feb 23, 2017 01:57 PM
Riffraff123
Mar 24, 2016 09:42 AM
