Down shifting to help brake
Old Apr 26, 2017 | 05:52 AM
YeOldeStonecat's Avatar
YeOldeStonecat
Yup...just like with cars, I downshift a bit while also gently braking...the combination helps slow one down. I gently downshift...sometime skipping a gear.
Yeah some people say it causes additional stress to the engine, clutch, and drive train. I'm sure if you do it incorrectly..that's true. And I'm sure even when doing it gently...it does cause a "little bit" extra wear.
Big deal.
Old Apr 26, 2017 | 06:19 AM
Jgig's Avatar
Jgig
I always match engine speed with bike speed during downshift (blip). Much smoother ride, if not coming to a stop. Also, passengers will greatly appreciate less jerking.
Old Apr 26, 2017 | 06:57 AM
sfcmo357's Avatar
sfcmo357
From my sport bike racing days.......I've always downshifted to brake. Yes, I use the brakes, but downshifting is my main technique. I don't slam the bike down a gear when going too fast ---but I appropriately downshift to match my speed....but by the time I do that, coming to a stop, I only have to use my brake for the last few feet.
Old Apr 26, 2017 | 08:14 AM
Brewmany's Avatar
Brewmany
Like others, I downshift as I slow down to match the gear with my speed, and so I'm ready to go when the way is clear. I don't use engine braking, and I'm careful to not downshift too agressively. I've heard that downshifting too low too soon can cause handling problems.
Old Apr 26, 2017 | 08:19 AM
OKMICK's Avatar
OKMICK
Originally Posted by Brewmany
Like others, I downshift as I slow down to match the gear with my speed, and so I'm ready to go when the way is clear. I don't use engine braking...
What exactly do you think downshifting is if it isn't 'engine braking'.
Old Apr 26, 2017 | 08:20 AM
Jackie Paper's Avatar
Jackie Paper
You, of course, need to down shift as you approach a red light and such so you will be ready if it turns green and such but brake pads and rotors are much more economic than all that silly clutching, shifting and unclutching's. And also all that wear and tear on the transmission and engine.
If you keep a bike for the long haul, just down shift and use the brake. If you just keep it a few years and drive it like on a rally track, use the transmission. If you do the latter, not sure why you would bother to do any maintenance, however.
Old Apr 26, 2017 | 08:35 AM
RHPAW's Avatar
RHPAW
Lotta guys used to claim that it caused scissoring on the flywheels for bikes made after 2002.
They would tack-weld their crank/flywheel assembly to prevent it.
Old Apr 26, 2017 | 08:40 AM
oct1949's Avatar
oct1949
DS'ing will and does slow you down a little, but mostly as lots of others have said, I do it as I slow down to be in the correct gear in case I need to accelerate without having to LUG the engine if I had to pick up speed..
And yes downshifting at "HIGH'' RPM's ""a lot"", can/could/will cause undue stress on engine parts...
Old Apr 26, 2017 | 08:42 AM
AJSHOVEL's Avatar
AJSHOVEL
Big deal.
Yep, down shifting (to help with slowing) and braking go hand in hand. You want to be in gear always for control.
Old Apr 26, 2017 | 08:43 AM
SBRob's Avatar
SBRob
Originally Posted by Iron25
I always downshift when coming up to a light/slowing down. That way Im in the right gear to get going again
^^^this^^^...
