Lost oil pressure?????
Old Apr 29, 2017 | 09:29 PM
Curtis English's Avatar
Curtis English
Stage II
Default Lost oil pressure?????
So I just got my first Harley. A 2006 street glide. I wanted to see if the cam tensioner upgrade was done and it wasn't. I replaced both cam tensioners with new pads, put it back together and the bike ran great. Looked up, no oil pressure. Unhooked where the sending unit is and checked with an actual gauge, nothing. plus no oil coming through the oil return line. I had good oil pressure before i tore into it. what could I have done wrong????? Tia
Old Apr 30, 2017 | 08:05 AM
dawg's Avatar
dawg
Oil is not getting through. There are two small o-rings on the ports where the plate meets the cam chest, as well as one at the rear of the oil pump. If one of these is not installed correctly or gets pinched when installing, it can cause some issues. Did you realign the oil pump correctly using either alignment pins or proper tightening sequence while rotating rear wheel? Did you have to reassemble the oil pump and perhaps mess up the wavy washer? Did you measure the specs to ensure the gerotors stand proud about 1 thousandth to ensure proper wavy washer orientation, etc? Did you go down through the rockers or cut the pushrods and install quickie rods? Just asking a bunch of questions to better pinpoint where you can start looking.
Old Apr 30, 2017 | 08:49 AM
Curtis English
Stage II
We checked all the o rings and they looked fine. I did buy the alignment pins and tightened it spec to the shop manual. And we did cut the push rods and installed the new adjustable push rods. Thanks for the help
Old Apr 30, 2017 | 08:56 AM
dawg's Avatar
dawg
Did you turn the rear wheel as you aligned the pump to see that oil came out as the wheel turned?
Old Apr 30, 2017 | 09:17 AM
bettingpython's Avatar
bettingpython
Did you change the bearing retainer plate out with a different one?
Salmo pass
Engine Mechanical Topics
Mar 4, 2019 03:17 PM
Pops98
Feb 1, 2015 05:05 PM
f4dennis
25
May 27, 2014 10:10 AM
Born2cure
Jun 3, 2012 09:13 PM
02Ultra EG
May 9, 2010 10:15 PM
