Solid vs Floating Rotor
Old May 16, 2017 | 08:01 PM
Pothole914's Avatar
Pothole914
Default Solid vs Floating Rotor
I have to replace the front rotor on my new to me Heritage.
I looked on the Harley site and found that there is only $10.00 difference in price.
What are the advantages or disadvantages in each?
Thanks
Old May 16, 2017 | 08:23 PM
FLSpringerSE's Avatar
FLSpringerSE
The primary advantage is that a full floater will line itself up to the pad surface when the brakes are applied to provided the greatest pad-to-rotor contact area. So, better braking efficiency and stopping power.
Old May 16, 2017 | 09:15 PM
Cobra1's Avatar
Cobra1
Aren't they also less prone to warping from excessive heat?.
Old May 16, 2017 | 09:19 PM
aecs's Avatar
aecs
In theory since you have a floating caliper like a car, the caliper will center itself.
Old May 17, 2017 | 12:27 PM
multihdrdr's Avatar
multihdrdr
His 2008 heritage doesn't have a Front floating caliper...they're fixed 4-piston
Edit: I added the "2008" and "Front" for further clarification...Rear is sliding (aka "floating") on an 08
Old May 17, 2017 | 01:22 PM
FastHarley's Avatar
FastHarley
Former Sponsor
Default Answer
His heritage doesn't having floating calipers...they're fixed 4-piston
+1 Just look at them before answering. The caliper would slide on a rod like the older HD did if it was a floating caliper.
Old May 17, 2017 | 02:24 PM
back again's Avatar
back again
Floating rotors dissipate heat much better than solid. Also make sure you you get compatible pads.
keith t
Jun 4, 2013 09:33 AM
garrgoyllle
Wheels/Tires
Apr 14, 2013 08:04 AM
Stew Pidaso
Jan 7, 2013 08:27 PM
brettnbama
Wheels/Tires
Jul 11, 2011 04:36 PM
FFeric
Mar 18, 2008 11:12 PM
