Electrical
Old Jun 12, 2017 | 10:24 AM
Rlkois's Avatar
Rlkois
Stage III
Default Electrical
Need some insight: 2013 Ulira Classic Limited; fuel gauge reads full with yellow low fuel light. Intermittent yellow engine light and red battery light (with voltage drop to 11). Replaced fuel sensor in the tank - works sometimes; still goes to full and yellow low fuel light on occasionally, but not always at same time. Still get once in awhile the yellow engine light and red battery light with voltage drop to 11.
Broken, frayed, loose wire? Which one?!
H-E-P-L (help!)
Old Jun 12, 2017 | 10:42 AM
Redoilokie's Avatar
Redoilokie
Check battery cable connections first, and any engine or frame grounds.
Old Jun 12, 2017 | 12:29 PM
SIDECAR BOB's Avatar
SIDECAR BOB
agree sounds like a ground issue
Old Jun 12, 2017 | 12:33 PM
deadhawg's Avatar
deadhawg
This. Check the simple stuff first. A bad ground can cause all kinds of issues. Clean and tighten all ground connections.
Old Jun 12, 2017 | 02:59 PM
Rlkois's Avatar
Rlkois
Stage III
Thanks folks. I'm on it.
Old Jun 14, 2017 | 01:43 PM
Redoilokie's Avatar
Redoilokie
Any luck?
Old Jun 15, 2017 | 07:01 AM
Rlkois's Avatar
Rlkois
Stage III
Any luck?
Yes. So, I removed +/- cables and removed the gray patina on the battery terminals down to shiny silver and replaced the cables. Also checked frame ground (tight) and located the triple tree ground in the batwing. Checked it tight and reviewed all wires between fuel level sensor to the gauge in batwing (no breaks or frays). Buttoned it all up and haven't have any issues on the last three rides. I kinda had that thought when I got the intermittent yellow engine light and red battery light - bad battery connection or a loose ground. Worked out so far! We'll see.
THANKS!
Pcrebuilder
Dec 15, 2014 09:25 AM
StreetGlidinFreak
Jan 12, 2013 06:23 PM
leepetersusn
Aug 22, 2011 07:26 AM
djwhaley
Jun 24, 2011 04:41 PM
OBXPAUL
Apr 8, 2011 12:42 PM
