Gps
Old Jul 31, 2017 | 09:17 AM
jeffscra's Avatar
jeffscra
Default Gps
Folks:
I'm looking to get a dedicated GPS. I'm not sure if I should try to get the popular 660 or if I should get the newer model 595LM. Anyone tried both? I know people also say the TomTom 400 is good too, but I think I like the Garmin products better unless I can be convinced otherwise. But from reading all the post here about both, I'm still leaning towards one of the Garmins. I want to be able to upload a prepared route into the GPS and then get turn by turn instructions.
I have been using my Iphone, with InRoute and it works ok, but I don't feel has the same functionality and information present as a dedicated GPS.
Thoughts?
Thanks,
Jeff
Old Jul 31, 2017 | 09:52 AM
Redlegvzv's Avatar
Redlegvzv
I have the 665 and really like it. If I were buying today though, I would probably go with the 595. No reason not to go with the latest and greatest. I use my 665 in conjunction with the Sina 20s and this works very well. The Sina 20 S works much better with the Garmin products that the then does the earlier SMH 10.
Old Jul 31, 2017 | 01:14 PM
dyna rider's Avatar
dyna rider
Default Garmin
Go with the newer products from Garmin. I bought a new 660 after they had been discontinued and for a while it worked great. Then while trying to update the unit, it failed and went dark. Since it was still under warranty, Garmin sent me a refurbished one. Not the best solution but better than nothing. Stick with the newer products.
I also like it a lot better than the Harley boom box GPS.
Old Jul 31, 2017 | 01:25 PM
baka1969's Avatar
baka1969
I have a TomTom and like it. I believe it's the START 50M. It's not the latest and greatest but does what I need it to do. I don't feel I need to spend $600+ on a motorcycle-specific GPS. I have mine on a RAM mount and when it rains I put it in a zip-top bag. If I had to replace it with another $125+/- version every 2-3 years, I'm way ahead of the game.
Old Jul 31, 2017 | 03:32 PM
Sierra977's Avatar
Sierra977
Same thing just happened with my 2595LMT. Lost Voice Command function when it was updated. Tried repeatedly to correct per Garmin customer service buy no joy. Garmin going to replace for $99.
ETA: It was out of warranty but it was Garmin's software update that screwed it up.
Old Jul 31, 2017 | 04:09 PM
jeffscra's Avatar
jeffscra
Do you guys all load routes for turn by turn instructions?
Old Jul 31, 2017 | 04:11 PM
jeffscra's Avatar
jeffscra
I'm curious how you use your Tom Tom? Just to see where you are going? Do you load routes? Is there voice instructions? Is it large enough and bright enough? I'm looking at all options.....new Garmins are not cheap.
Thanks
Old Jul 31, 2017 | 05:00 PM
Statuesque's Avatar
Statuesque
I have loaded routes into various Garmin devices, no experience with the 595LM, but my concern is if you want turn by turn directions for your own route, do you just want them visually or be able to hear them too? My experience is that most of the time the GPS volume is not loud enough to hear decently under usual riding conditions, and I'm not a fan of having a loud bike either and still had trouble with being able to hear aspect without loud pipes. Now if you are planning on using some kind of headset that you can sync thru Bluetooth, then different story. Looking at your signature I don't see any bike speakers you can connect too. Believe your issue is going to be hearing the unit if that is what you are looking for with any unit.
Old Jul 31, 2017 | 05:03 PM
Cosmic Razorback's Avatar
Cosmic Razorback
Community Influencer
Active Streak: 30 Days
Get something you can see in the sunlight. The first HD gps I bought back in 2008 was great. It finally died around 2013 and the replacement HD unit at that time was terrible in the sunlight. Then the touch screen quit working. Did the process you go through to calibrate it twice. No luck. Learned you could send it back after I already trashed it. Didn't matter since it was useless in direct sunlight.
I cannot remember the model numbers? Sorry
Old Aug 1, 2017 | 03:40 AM
LQQK_OUT's Avatar
LQQK_OUT
I have a Garmin 660, but I highly recommend spending the extra money for a 595 over the 660. A friend of mine recently purchased a 595. The 595 has a faster processor, larger screen, more features, etc.
If you plan to do a fair amount of creating routes using Garmin's Basecamp, I would avoid the Garmin 66X units, and get one of the newer units (595, 395). The older Garmin units are not fully compatible with Basecamp. This is a documented issue and Garmin even says: The following devices are NOT compatible with routing in BaseCamp:
zumo 400 series
zumo 500 and 550
zumo 660 and 665
There are also issues with via points and reshaping routes.
I do create routes in Basecamp and have noticed a number of these issues on my 660.
