have a 06 ultra classic my chain case is leaking. I changed the gasket with oem Harley went for a ride on Sat came home and have a puddle under it again. I heard that they make a gasket with a bead on it that seals better anyone heard of this? Or know why a new gasket would be leaking? Thanks for any help!
yes i looked at the seal for the shaft when i had it apart the first time. I thought it was a bad i even bought one but the allen head just needed a tightening. i also can see it leaking from there when i wipe it off i see it seeping there. the dealer said it was a warped cover but i dont see it just all the sudden warping.
Thank you guys for the info my new parts just came today going to do a thin coat of RTV and see what happens. Have to do breaks too. thanks again for the help guys, everyone be safe.
I had an evo that the primary cover was warped. I never had a problem with it until the first time I took it off. When I put it back on I couldn't get it to seal. I couldn't see the warp until I put a straight edge on the seal edge of the cover and I could see the gap. Hopefully the new gasket works for you.
