How many frozen brake pedals and levers?
Old Dec 18, 2017 | 01:23 PM
wibiker's Avatar
wibiker
Here's some more failures that I found in the ticking time bomb thread:
old95, 09 RG, front, 4/16
CR3999, 10 RG, front, 5/16
Farmerguy, 10 FLHTK, rear, 5/16
ngshop's friend, 09 RG, rear
Evillordmoonglum, 12 FLHTK, front, 9/17
Old Dec 18, 2017 | 04:11 PM
skratch's Avatar
skratch
Originally Posted by upflying
I reckon the corrosion and frozen controls is from lack of maintenance. Brakes need to flushed every 2 years to get the moisture out of the fluid.
Originally Posted by lh4x4
Never! Many bikes with ABS and many miles. All I ever did was flush them at the indicated service interval. Gee! I wonder if that helped?
Ticking time bomb = BS Just take care of business like all responsible adults do.
OP Are you a Crusader or Don Quixote?
not necessarily. my wife's bike wasn't even 2 years old yet when it happened to hers.
Old Dec 18, 2017 | 06:43 PM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
None for me...so far.
Old Dec 19, 2017 | 08:46 AM
screaminroadking's Avatar
screaminroadking
My 08 CVO Roadking. Rear brake frozen solid, and yes I did proper maintenance by flushing the brake fluid as recommended. 28.000 miles at the time.
Old Dec 19, 2017 | 09:09 AM
benscratchin's Avatar
benscratchin
No problems with my 2012 SG.
I received a SB letter from H-D (in the mail I believe) I'll have to find it. Anyway, it stated the suggested service interval for "Brake system fluid flush and replacement". I believe it was something like every 2 years or 20,000 miles. I need to look at the letter.
Old Dec 19, 2017 | 09:14 AM
DGDeuce's Avatar
DGDeuce
I'm getting both the HCU and the ABS replaced. I take my daughter for rides and want the piece of mind that it fixed. I didn't want it to turn out to be the ABS whenI fixed the HCU and later get a "surprise" with my daughter on the back.
Old Dec 19, 2017 | 09:20 AM
PDB17UltraRG's Avatar
PDB17UltraRG
My friend 2014 roadglide is locked up been that way for a while now he dozen have the money to fix it. Is there a recall on this it is front brake were would he start would a fluid flush help out or are there part to change. Any info would help
Old Dec 19, 2017 | 09:30 AM
dceggert's Avatar
dceggert
Originally Posted by wibiker
How many riders have experienced frozen ABS brake controls resulting from the failure of the early (08 -12) ABS units. Apparently a corroded ABS valve malfunctions resulting in hydraulic lock of the lever or pedal rendering that brake useless.
There is more to this then just yes/no. Was there not an ABS module change on the 2014+ Touring line? That may also be a factor. It seems that most of the module 'failures' are from the 2007-2010 timeframe. It may be more than just time in service or time without a fluid flush. The particular failure mode may be related to the earlier module or it may be both. Anyway, of those that have the issue it would be nice to know if the fluid was regularly serviced and which module was involved.
Old Dec 19, 2017 | 09:59 AM
NORTY FLATZ's Avatar
NORTY FLATZ
A hydraulically operated braking ststem is an incredably simple design. They've even been around so long that even the old school riders accept this new fangled technology. Yet, Harley still found a way to screw it up.
If HD made aircraft, would anyone fly it?
Not without a parachute!
I tell ya, HD is almost equal to the gov't. Equally inept...
Old Dec 23, 2017 | 12:45 PM
wibiker's Avatar
wibiker
Some additional failures I found in the forum:
dowhat, 08 RG, front, 12/17
Bubracin3, 08 SG, front, 11/17
imakook, 10 Ultra, front, 3/15
dtomlin, 10 Ultra, front, 2/17
KumaRide, 11 RK, front
It would be great if every ABS failure got reported to the NHTSA at safecar.gov
