One passing light out
Old Oct 10, 2017 | 07:12 AM
Tom84FXST's Avatar
Tom84FXST
Originally Posted by Bluraven
It's not the ground.
The problem is differently related to the hot wire.
Copper broken inside the insulation...it has enough of a connection to read on a meter...but as soon as you put a load on it, it opens up...seen it a hundred times.
Old Oct 10, 2017 | 12:03 PM
junior07's Avatar
junior07
My question is "What is a 'passing' light?
Am I supposed to turn a light on when I pass someone? Or is this something on the baggers?
I guess I've been doing it wrong.
Old Oct 10, 2017 | 08:29 PM
Veekness's Avatar
Veekness
Old school name for a 'spotlight '.
​​​​​​​All is well.
Old Oct 13, 2017 | 01:51 PM
Bluraven's Avatar
Bluraven
Well the problem is power to the passing light.
It appears I've got a "partial" open somewhere.
From the wiring schematic there's only 2 connections that are dedicated to each individual passing light.
From the on/off switch power continues through a single wire to connector 73A/B.
At connector 73A/B power is broken into two wires going to connectors 73RB and 73LB.
So if the problem was before connector 73A/B both passing lights would be impacted.
My bet is a bad connection at connector 73A/B..
Well it didn't take long to locate the issue.
As expected the problem is inside connector 73A/B.
I don't have a 2 wire connector handy so I just spliced the right passing light power wire into the left passing light power wire.
BTW- to access this area all that's needed is to loosen the two bolts on each side and remove the allen screws (1 on the left and 2 on the right).
Then the covers come off.
No response needed here, I just hate people posting a problem but don't post the fix.
All is now well.
ondeeeznuts
General Topics/Tech Tips
May 4, 2018 05:58 PM
86Drifter
Aug 20, 2014 03:02 AM
PowerSmoke
Jan 30, 2012 06:48 PM
goodryde04
Electrical/Lighting/Alarm
Mar 15, 2011 10:39 PM
1993mooglide
Jun 19, 2009 07:13 PM
