electrics
Old Oct 14, 2005 | 12:31 PM
bob byrne's Avatar
bob byrne
Stage I
Default electrics
i changed a sportster motor due to a bent frame. the motor ran great in the bent frame. i am getting power to the starter but it is not turning all the wires to the starter are hooked up. i know just aenough about electrics to keep me in trouble,check voltage and continuity. is there some kind of ground or something that i am missing. thanks for any help. i dont know where that rubbernecker on the address came from
Old Oct 14, 2005 | 12:56 PM
screamn_eagle's Avatar
screamn_eagle
Default RE: electrics
HI BOB, WELCOME TO THE FORUM...FIRST OF ALL THE RUBBERNECKER IS YOUR RANK IN THE FORUM, AS YOU POST MORE YOU GET DIFFERENT TITLES. SECONDLY I DONT KNOW JACK ABOUT ELECTRONICS, BUT THERE ARE ALOT OF PEEPS HERE THAT DO. THIRD LOOK IN THE DIFFERENT AREAS OF THE SITE FOR YOUR ANSWER AND YOU MIGHT WANT TO POST IT IN THE APPROPRIATE SECTION. AND LASTLY POP INTO THE NEW MWMBERS AREA AND INTRODUCE YOURSELF. WE LOVE NEW MEMBERS AND ALSO PICS SO IF YOU HAVE AND PICS OF YOUR SCOOT GO AHEAD AND POST THEM....AGAIN WELCOME FROM SO FLA
Old Oct 14, 2005 | 01:57 PM
pointswhat's Avatar
pointswhat
Give it a firm TAP with a hammer but don't try and bat it out of the park. Not sure exactly what the problem is but it often works and usually makes me feel better.
Old Oct 15, 2005 | 03:23 AM
Ronster98's Avatar
Ronster98
Your getting power to the starter, how/where are you measuring? The positive off the battery connects to the starter directly, then jumps off to a circuit breaker to the ing. switch. From there it goes to the NO connection of the start relay and also splits off through a fuse then to the start/stop swirch to the start switch then back to the start relay coil connection. The relay is grounded and then closes when the circuit is complete to supply power to the starter. The ground is what is switched to start the bike. See the attached schematic from my '98 sportster service manual. Trace the whole thing out and see where your missing a connection.
[IMG]local://upfiles/3459/5ECDE45BF72F4D9D9D71415DE9A82568.jpg[/IMG]
jgreco123
EVO
Sep 24, 2017 04:52 PM
jamiefixit
Apr 12, 2015 05:04 PM
mark81
Jun 21, 2009 07:19 PM
radio915
Shovelhead
Apr 29, 2009 08:37 PM
wbogley
Shovelhead
Nov 28, 2007 09:42 PM
