Coverage under warranty question
Old Oct 26, 2017 | 01:13 AM
TroutBum's Avatar
TroutBum
Question Coverage under warranty question
Last week I brought my 2017 XL1200C into my dealer to replace some bits damaged when I had to fall over to avoid a van driver that decided to backup while at a stop light. Anywho, no real damage to the bike just a slight bend to the clutch lever, loosen mirror pivot, slight bend in the foot control shifter and a minor scratch to the derby cover. The bike landed on me for the most part. Everything else was spared, thank goodness. When the HD tech started the bike after the replacement work he said he heard a noise coming from the primary. The cover was pulled and everything checked out, but he said the clutch plates where way out of spec and that it would need replacing and that I would have to pay for it. The bike was purchased brand new back in June a has less then 2,500 miles. Shouldn’t this be a warranty job? The shop manager is going to call HD, but thinks it will be denied. What are your thoughts on this? Should it be covered under warranty or am I going to have to pay for the repairs?
Old Oct 26, 2017 | 01:31 AM
From_Behind's Avatar
From_Behind
Did the tech say that it was damage in the accident?
Old Oct 26, 2017 | 03:08 AM
Daytona Fat Boy's Avatar
Daytona Fat Boy
I would be surprised if the factory doesn't cover it. I've owned Harleys for 25 years. The few times I've had problems, the factory has covered them.
Old Oct 26, 2017 | 05:35 AM
Mxdad's Avatar
Mxdad
I'm not exactly sure what is meant by "clutch plates were way out of spec" my guess is they were worn to the point they needed replacement. If that is the case I could see it falling under a normal wear item like brake pads, tires etc... and not being a warranty item. I agree that 2500 miles is way to soon to see clutch plates need replacing unless something else is going on, clutch out of adjustment, riding the clutch etc....
Old Oct 26, 2017 | 05:44 AM
RK_Classic's Avatar
RK_Classic
First off glad you didn't get run over. Second if you had the dealer do your 1K service they should have checked / adjusted you clutch properly. If thats the case and they did the adjustment wrong somehow then they should be responsible. They should not be responsible for bad rider habits if thats the case. I'm sure more will chime in.
Do clutch plates make noise when going bad??
rk classic.
Old Oct 26, 2017 | 06:27 AM
Kenny94945's Avatar
Kenny94945
I'd agree with post # 5,
If 1000 service was done.
2500 and have clutch plates burned out is rare....and to me implies improper adjustment ....or the clutch fiber material was faulty and failed.
As secondary evidence, rear tire is original and still looking new?
Yes, talk with the dealer first or call the factory hotline for insights.
Let us know how it works out.
Good luck.
Old Oct 26, 2017 | 07:08 AM
GRWHD's Avatar
GRWHD
As stated if you had your 1000 miles check up it should have been checked/adjusted then.
It should not be normal wear and tear @ 2500 miles....
Unless you kept riding the bike after the fall ....?
If yes you could have damaged it by riding it, and then who knows if they will cover it.
Old Oct 26, 2017 | 07:15 AM
shanneba's Avatar
shanneba
If you did have the dealer do the 1000 mile service, what fluid did they use in the primary / transmission?
If you do have to replace the clutch, and it isn't covered under warranty, I would suggest not replacing with the stock clutch plates. The stock clutch includes a "spring" plate, two friction plates riveted together.
That plate is known to wear the rivets and cause problems.
I would suggest the HD SE Performance clutch kit
https://www.harley-davidson.com/stor...nce-clutch-kit
It also has a heavier clutch spring, takes a little getting used to with the heavier pull.
It was less expensive than the stock clutch when I had mine replaced.
Barnett and Energy One also make "extra" plate clutch kits that remove the stock "spring" plate.
Old Oct 26, 2017 | 07:26 AM
Larry Davis's Avatar
Larry Davis
Hope they cover your clutch cost. Now, as to the incident with a van backing up ...... good lesson to be learned there. A sign of a new rider or a rider that has developed some bad habits is how close they stop behind other vehicles at traffic lights, stop signs, etc. Good rule of thumb is keep a standard vehicle length away from the one in front of you and stay to one side or the other so they can see you in their outside mirrors, preferably the side that gives you a way out if needed. Please take this the right way. May save your life someday!
Old Oct 26, 2017 | 07:40 AM
Uncle G.'s Avatar
Uncle G.
Clutches are one of those “iffy” areas when it comes to warranty replacement. Like brake pads, clutches are a “wear item”, and, as such, are usually excluded from warranty coverage. Still, I think it would take an abnormal amount of abuse to wear out a clutch in 2500 miles. Then again, what do I know? I’m an old man and ride like one.
