Fork Damage
Old Nov 16, 2017 | 07:02 AM
Omega3's Avatar
Omega3
6th Gear
Default Fork Damage
Bought a 2013 street glide that had some damage to the fairings. It also had a cut in the tire and a chunk broken from the front wheel. I haven't taken the forks off to verify that they are perfectly straight. But they don't really look bad at all.
Input from techs or people that have dealt with this before would be appreciated.
thanks
Old Nov 16, 2017 | 08:59 AM
upflying's Avatar
upflying
You knowingly bought a bike with collision damage? And now asking what you should do? Did you buy it with a salvage certificate?
At some point, an insurance company determined the damage exceeded the value of the bike. What ever the bike struck probably tweaked the frame. Buying a crashed bike is a can of worms, no one knows until you open it up. If it were me, I'd check to see if the frame is straight before doing anything else.
Old Nov 16, 2017 | 10:03 AM
nevada72's Avatar
nevada72
thanks
If it were me I would throw on a good wheel and tire and see how it rides out. These things aren't space shuttles. I've ridden bikes with bent stuff many times. But with any luck you're good to roll.
Old Nov 16, 2017 | 11:45 AM
Omega3's Avatar
Omega3
6th Gear
I thought the same thing. I have had many different bikes with different things wrong and fixed them. I have had sportsters with front end damage and not one time did the frames get bent. Not saying it can't happen. But what i do know from taking Harley's apart the frames are extremely stout. Unlike an Indian, where their frames snap off like potato chips.
Its all fixed for the most part but was just wondering about the forks. It looks great.
I probably will take the front apart again though and check the forks.
Old Nov 16, 2017 | 04:56 PM
nevada72's Avatar
nevada72
You pretty much have to do that to drain the fork oil anyway, which it probably needs anyway, so why not?
While you're in there, maybe some black or chrome lowers? Also use the heavy duty fork oil and remove some of the mushiness.
Old Nov 16, 2017 | 05:28 PM
OlAndrew's Avatar
OlAndrew
Take the lowers off the fork tubes, take the tubes out of the triple tree and fork clamp. Roll the tubes along a FLAT surface. If they roll smoothly, OK. If they wobble, they're bent.
Tubes can be straightened with careful work on a hydraulic press. ITs handy if you have a block with a hole that's just a couple of thousandths larger than the diameter of the tube. If the block slides all the way along the tube, its straight.
Used to have a straight steel rod about 3' long. At the top, there were threads and two cones, so that you stuck the rod up through the frame stem and tightened the cones on the bearings. If the rod stuck straight down, the end was equadistant from teh frame down tubes, the stem was true and the frame likely was.
You'll usually see paint flaking away from frame bends.
I used to work in a frame and fork shop. We did repairs for insurance companies.
Don't ride if anything's bent. Handling can get REALLY squirrley, especially in an emergency.
Old Nov 17, 2017 | 01:40 AM
bklynbob's Avatar
bklynbob
Custom cycle engineering has some nice low friction tubes.......
Old Nov 17, 2017 | 08:30 AM
NORTY FLATZ's Avatar
NORTY FLATZ
A pair of "V" blocks and a dial indicator...
Old Nov 17, 2017 | 09:04 AM
Dirty Harry's Avatar
Dirty Harry
Any idea of what normal run out might be ???
Old Nov 17, 2017 | 09:28 AM
TwiZted Biker's Avatar
TwiZted Biker
Yeah these things aren't near as fragile as people think.
OP check the tubes for straightness and pay attention to how each one drops out of the triple trees, if they fight you chances are the trees are tweaked.
evilrider
General Topics/Tech Tips
Aug 2, 2016 01:39 PM
Mercyfulfate
Sep 13, 2013 05:59 AM
RadarRider
Jul 21, 2011 01:15 PM
fjfscooter
Ironhead
Mar 27, 2008 05:34 PM
swomack
Feb 4, 2008 02:20 PM
