Radio cutting in and out
Old Nov 24, 2017 | 01:30 PM
Flip50's Avatar
Flip50
Default Radio cutting in and out
2016 road glide with 5000 miles. Radio cutting in and out just began recently.
Old Nov 24, 2017 | 01:55 PM
SPRINGER's Avatar
SPRINGER
Just a guess but could it be a loose wire connection?
Old Nov 24, 2017 | 02:25 PM
Flip50's Avatar
Flip50
Thanks springer. Also have heard to turn speed adjustment off. I tried that and so far not cutting in and out as I have not ridden it yet I will know if that did the trick. Thanks .
Old Nov 24, 2017 | 02:39 PM
dickey's Avatar
dickey
Said it before & I'll say it again...you don't need a radio on your bike; the pipes make that sweet music for you to hear.
Old Nov 24, 2017 | 02:45 PM
Cygnusx51's Avatar
Cygnusx51
No one ever said it was a “need”.
OP, to take the outer fairing off is really easy, there’s plenty of YouTube videos to show you, it only takes a few minutes. Might as well give it a look and see if there’s any loose or rubbed wires. Being a 2016...it should also still be under warranty so a dealer can take a look as well and hopefully replace anything that might need to be for no charge.
Start simple though....if you have the Road Glide Special, check your NAV to see if there’s still an active route going. If you had a route active at some point and haven’t selected “Stop”, it’s still running in the background, the radio cutting out is the voice commands still talking to you.
Old Nov 24, 2017 | 02:54 PM
Flip50's Avatar
Flip50
Yes still under warranty. Just thought it might be something simple. Or some one with same experiences could pass on some thoughts. And yes the pipes do sound good too!
Old Nov 24, 2017 | 03:13 PM
UUNetBill's Avatar
UUNetBill
Now when you say ‘cutting out’ I assume you mean just the sound, not the power?
If it’s just the sound, double check the Nav like Cygnus said - that was doing it on mine right after I got it and it was driving me nuts for a day or so. You can turn off the voice prompts in the Setup menu, but some of us (me included) have had that default back to ‘On’ sometimes...
Old Nov 24, 2017 | 03:40 PM
Flip50's Avatar
Flip50
Smile
Solved . Yes navigation was still activated. Pwr was still on but sound was cutting off intermittently . Now to go stop the route. Thanks . Now to try to cut out destination . Accidentally deleted all previous routes which I probably can't retrieve but that's ok.
Old Nov 24, 2017 | 04:41 PM
Cygnusx51's Avatar
Cygnusx51
As long as you go to the map screen and stop the route, that will get rid of it. Like UUNetBill said, in the settings you can disable the prompts all together but with certain software updates, that setting seems to reverse itself the next time you set a destination. Some people have the issue, some don’t. Not sure what causes that.
95 Ultra
EVO
18
Jan 16, 2021 04:36 PM
Skippy49
Audio Systems
Mar 28, 2016 05:43 PM
Skippy49
Electrical/Lighting/Alarm
Mar 28, 2016 11:40 AM
NO4NMTL
Apr 6, 2011 10:32 PM
Edz05
General Topics/Tech Tips
Jan 29, 2011 11:46 PM
