Anyone have a fuel injector go bad or start acting up?.,,
Old Nov 30, 2017 | 10:30 PM
big cahuna's Avatar
big cahuna
Originally Posted by 6 gun
05 Road King someone thought they saw a little smoke, maybe it's time for a newer Harley. Or at least a 120 engine, that is the angle I would go with to convince the wife that it's time for an upgrade. "dang I like spending other peoples money for them" LOL
Only way I could spend any money, is if you gave me some.,,,,
Old Nov 30, 2017 | 11:01 PM
6 gun's Avatar
6 gun
Don't look at me I'm as broke as the ten commandments, that is why I'm trying to spend your money on you LOL
Old Dec 1, 2017 | 04:40 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Check your plugs and wires. Maybe one isn't firing correctly.
Old Dec 1, 2017 | 08:43 AM
Mike Lawless's Avatar
Mike Lawless
Injectors are mechanical devices and CAN fail. But, they have been proven to be very reliable.
Typically, they get "varnished" over time. The spray pattern will degrade to the point that the fuel sputters and dribbles out rather than a strong spray mist. On my own bike, I think I may have that problem. So, over the winter, I'll remove 'em, and send 'em to a place that specializes in fuel injection to have 'em cleaned and checked.
In your case, you might suspect that one or both are hanging open. If that is the case, it would show up as raw fuel still coming out of the pipe (Black smoke). You fuel mileage would be bad and the plug(s) would be black and sooty. That is the first thing to check.
If it's oil that's burning, the smoke would be blueish. If it's bad the plug would be oily looking if it were really bad.
So, determine what liquid is being used up at an abnormal rate. Fuel or oil? Then pull the plugs and look at 'em. Do a compression check or leakdown check if you suspect excess oil consumption.
Don't guess. Diagnose. Then you'll have a course of action.
Old Dec 1, 2017 | 01:48 PM
Bodean46's Avatar
Bodean46
My 01 had a rear injector hang open, ran great, just a trace of black smoke once in a while. Finally started fouling rear plug, so I ordered new ones from HPI and have not had a problem since.
Old Dec 2, 2017 | 04:46 AM
geezer glide 56's Avatar
geezer glide 56
2005 models had a problem with the valve guide seals. Check your spark plugs, if one or both of them have a crusty build up on it, you will need to replace the seals.
Old Dec 2, 2017 | 09:01 AM
big cahuna's Avatar
big cahuna
I just changed them out a month or so ago, and they looked fine. Never had any oil consumption issues or even leaks with the bike. Has a little over 66k on it.,,,
goosehntr
Aug 22, 2010 12:29 PM
08Fatty
Apr 4, 2010 09:01 AM
Bigredone
Jul 19, 2009 09:09 AM
FloridaDrafter
Apr 29, 2008 06:57 PM
Xtreme Hawg
Oct 25, 2006 11:56 PM
