Winter storage
Old Dec 29, 2017 | 10:34 PM
yodasan's Avatar
yodasan
Stage I
Default Winter storage
6 months ago I de-fueled and removed the battery from my 2013 wide glide, I am back now from deployment and ready to start up my bike.
Is there anything that I need to do other than re-installing the battery and putting fuel in the tank?
Old Dec 30, 2017 | 02:29 AM
riteway's Avatar
riteway
Thumbs up
Check/Change fluids...Check air. Might check status of battery before putting in,could save you some time...
(FYI pros and cons to actually removing gas as aposed to topping off with fresh with a good stabilizer, a lot of threads on the subject here on HDF..
Good Luck....Ride Safe
Welcome to the Forum...
Thanks for your service!!.....
Old Dec 30, 2017 | 08:45 AM
NORTY FLATZ's Avatar
NORTY FLATZ
Original battery? If so, then toss it.
T-CLOCS your bike.
Ride safe, and welcome to the site!
Old Dec 30, 2017 | 08:57 AM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Let her rip unless she has marked her spot. Which I doubt. Of course you have stuck the maintance charger on the battery for a couple days.
If it was a Softail, the dipstick would be low depending on how much the check valve in the oil filter leaks
I spend the winter south and my Harley sits this long now. An 04 with 50k and still runs like new.
I do nothing to it to prepare it.
Probably good idea to remove battery. I am sitting here wondering what could happen to battery. Two months before I will see bike and the maintenance charger is on it????
Old Dec 30, 2017 | 09:03 AM
Bluraven's Avatar
Bluraven
First off; Thanks for your service!!!
6 months being parked won't hurt anything.
Here's my recommendation;
1) Check the tire pressure.
2) Get some silicone spray lubricate and hit every lever and moving joint that you can get too
3) Fully charge the battery
4) Put fresh fuel in
5) Check all fluid levels (change them all if they have more than a few thousand miles on them since the last change)
6) Pull the plug wires off so the bike will not start
7) Hit the starter 4-5 times for a few seconds each to get the fluids flowing to get everything lubricated
8) Put the plug wires back on
9) Start the bike
10) Go enjoy the ride!!!!
All that being said, as Ripsaw eluded too; you can probably just put fuel and a fully charged battery in and everything will be fine.
Old Dec 30, 2017 | 09:11 AM
smitty901's Avatar
smitty901
6 months is not a long storage charge battery fully. Fresh gas, fire it up. Of course check all the stuff you check before a ride take it easy for a bit .
Welcome home. After the family and other things that need do when you get back always a joy to get the bikes outs.
Old Dec 30, 2017 | 09:14 AM
Spartanden's Avatar
Spartanden
First, thank you for your service.
Second, Welcome from Spartan Country Michigan.
Lastly, lots of good advice.... you should not have any major issues. Good Luck!!
Old Dec 30, 2017 | 01:08 PM
Geoff's Avatar
Geoff
Check the tire pressure and oil and then start her up. Anything more is overthinking it.
Krazy8s
Dec 2, 2016 08:48 PM
jd_OutNbout
Nov 28, 2013 06:07 AM
Aylor70
Apr 1, 2013 06:46 PM
CalSport10
Feb 18, 2009 04:21 PM
RK_Custom
Nov 16, 2007 11:27 AM
