First HD...so much to learn
Old Jan 31, 2018 | 08:33 PM
1LargeDog's Avatar
1LargeDog
Default First HD...so much to learn
Bought my first Ultra a few months ago. A 2010 with 7000 miles. A few weeks ago the bike was dead. Battery was 3 years old so I figured it was time for a new Deka. But to me something was still off. With the key on it still powered everything but would not crank. Someone mentioned the fob batteries die. Could it be that simple? Put a new battery in the fob and she fired up. WTH? Any more surprises in store for me? 🐖
Old Jan 31, 2018 | 08:49 PM
nobodyknowsme's Avatar
nobodyknowsme
This is not meant to be condescending.
KISS
Old Jan 31, 2018 | 09:56 PM
skratch's Avatar
skratch
have you changed your pin yet? if not, then there could be a very big surprise in store for you.
it's a simple process, clearly outlined in your owner's manual. i would recommend that you change it, and go through the pin override process a couple of times to make sure that you are proficient at it. dead on the side of the road is not the best time to be learning how to input that pin.
also, be aware that you can get hit with electrical interference which will keep your bike from recognizing your pin. don't waste your time trying to push your bike all around the parking lot trying to find an open spot. just use your pin. easier to push turn signals with your thumbs than a 900lb tourer.
if you're having trouble getting your pin entered, make sure that you don't have the fob right there with you. an intermittent signal will mess you up every time. and don't keep it in the same pocket as your cell phone.
Old Jan 31, 2018 | 10:21 PM
1LargeDog's Avatar
1LargeDog
Good stuff Skratch. Guess I’m just too old school. Still have a flip phone......lol.
Old Feb 1, 2018 | 06:16 AM
Bubba Zanetti's Avatar
Bubba Zanetti
Wait until you have to change your compensator
Old Feb 1, 2018 | 08:38 AM
Veekness's Avatar
Veekness
Surprises are why we ride Harleys, OP!
Old Feb 1, 2018 | 08:46 AM
HarleyBP's Avatar
HarleyBP
If you have an Operators Manual, it would be worth the time to read through it. I learned a lot from that manual when I switched over to HD.
corliss@bakerdrivetrain.com's Avatar
Part of the gig.
Old Feb 1, 2018 | 08:59 AM
NORTY FLATZ's Avatar
NORTY FLATZ
1000 miles per year use?
You didn't waste your money on a new Deka.
Yes, RFI can cause havoc with FOB's.
Don't park near low slung high voltage lines, nor transformers. This applies to Corvettes too!
Old Feb 1, 2018 | 12:19 PM
1LargeDog's Avatar
1LargeDog
I would have changed the battery anyway. Been using Deka for years. Yep, only 1k per year.
One of the reasons I jumped on it.
What about Mustangs???
