Best way to clean inside fuel tank.?
Old Mar 10, 2018 | 03:27 PM
HarleyD1929's Avatar
HarleyD1929
Default Best way to clean inside fuel tank.?
Took the petcock off cause it leaks and found several flakes in it.. Looks like paint.. I put a scope in the tank and saw where they came from.. The coating inside is flaking off, no rust thru, but there are rusty spots.. It's an 02 883 Custom stock tank..
I'm not a paint and body man, but if I could climb in there with a wire brush and a can of Krylon.... 🤓
Old Mar 10, 2018 | 04:04 PM
hellonewman's Avatar
hellonewman
I use a product called "chef" which is for grills in commercial kitchens. It will remove anything inside a fuel tank including rust.
Old Mar 10, 2018 | 04:20 PM
panz4ever's Avatar
panz4ever
Happen to have a link perhaps? The inside of my 78 FXE that I just got needs the inside cleaned out and I was hoping not to have to take it to the guy that boils my radiators out. A bit worried about the original paint and decals.
To the OP, don't mean to jack your thread.
Old Mar 10, 2018 | 04:28 PM
HarleyD1929
no problem.. I googled and found a product called Turbochef.. Not sure if it's the same one..
thanks.. I assume the flakes are a primer or sealer inside the tank, do I need to replace it. ?
Old Mar 11, 2018 | 07:14 AM
2goldens's Avatar
2goldens
Once you get it clean, try Caswell tank sealer. When my bike was painted last year the painter sent the tank to a guy to clean and seal even though it was a brand new tank from J&P. He put the tank on a rotisserie to evenly coat everything inside. He says the stuff will last forever.
The last tank had sheets of HD Tank Creem peeling off.
Old Mar 11, 2018 | 07:38 AM
Ron750's Avatar
Ron750
Gets great reviews:
Amazon Amazon
Old Mar 11, 2018 | 07:54 AM
Iceman24's Avatar
Iceman24
IMO...save yourself some time and just get a new tank. This way you can get it painted to your liking which gives your ride a fresh/new look.
Old Mar 11, 2018 | 09:08 AM
nevada72's Avatar
nevada72
If it's flaking inside you need to be pretty aggressive to remove the coating. I use methyl ethyl ketone. Fill the tank and let sit two or three days. it's nasty, nasty stuff that will eat the paint and your lungs if you're not careful. After that I rinse thoroughly with a hose and then I fill with distilled vinegar and a cup of salt to etch the metal and remove any rust. Once that process is done it should look like brand new metal inside. If it's severely rusted you may need to toss in stones, nuts, bolts, small chain, or whatever you have and "tumble the tank between step 1 and step 2, but in that case I would buy a new tank as by the time you are done there could be pin holes.
Then coat. I like POR but the other stuff recommended sounds good too. Tank has to be supremely clean and dry otherwise you are back to the beginning.
Old Mar 11, 2018 | 10:00 AM
HarleyD1929
that would be great, but my budget says I have to work with what I got..
Old Mar 11, 2018 | 10:04 AM
HarleyD1929
I don't think the rust is that bad, just visible rusty spots in there.. I saved the video from the scope, but can't upload it. It's an MP4, guess that's why..
