Well shit...
Old Mar 28, 2018 | 08:12 AM
WJBobber15's Avatar
WJBobber15
Stage III
Default Well ****...
Battery keeps dying out while riding and then coming right back on. It dies for a second RPMs drop and then goes right back to normal very intermittently. But went to ride this morning..started slow...but started and then rode for about 15 seconds and it completely died out.. now power now. HELP.
Old Mar 28, 2018 | 08:19 AM
Veekness's Avatar
Veekness
Check connections starting at the battery and working out. Basic electrical 101. Once you'e moved past the simple stuff, start working up the ladder. Like the ignition switch.
Old Mar 28, 2018 | 08:21 AM
bagga's Avatar
bagga
what year bike? could be the main circuit breaker.
Old Mar 28, 2018 | 08:24 AM
WJBobber15's Avatar
WJBobber15
Stage III
2015 street bob 4k miles
Old Mar 28, 2018 | 08:31 AM
hd4evr2008's Avatar
hd4evr2008
Sounds like a loose battery cable..............start there.
Old Mar 28, 2018 | 08:35 AM
Cygnusx51's Avatar
Cygnusx51
Well, you know what the problem is, check the battery. Connections, load test, replace. Beyond that, it could be something else but you may as well start with the easy stuff.
Old Mar 28, 2018 | 08:46 AM
sfcmo357's Avatar
sfcmo357
Happened to me after getting serviced, once. Kept scaring the ish out of me cutting on and off.........pulled the seat and it was a lose battery terminal
Old Mar 28, 2018 | 09:20 AM
mjrfd99's Avatar
mjrfd99
Yep. IMHO bad ground. BTW cables can go bad under their insulation.
My Shovel rattled a few to death.
Old Mar 28, 2018 | 09:49 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
After all of that...have the battery checked for a dead cell.
Old Mar 28, 2018 | 09:52 AM
WJBobber15's Avatar
WJBobber15
Stage III
Appreciate your response as well as your service Top!
