EVAP Canister Delete
Old Apr 30, 2018 | 08:27 PM
Mattbastard's Avatar
Mattbastard
Yup, all are pre-wired, CA bikes get the canister, purge solenoid, and lose the resistor. The purge solenoid redirects tank vapors into your carb when a vacuum is present. You also need to remember to plug wherever that hole is.
The ECM doesn't measure tank pressure, it measures the solenoid feed and if it's open it triggers the CEL. I went with around 1000 ohms since that's what heard the OEM resistor was valued at (and later confirmed when I actually bought one).
Old Apr 30, 2018 | 08:30 PM
vizcarmb's Avatar
vizcarmb
So are you trying to save weight or using the extra space for anything special? Removing the CA emissions stuff isn't going to add any hp and maybe take 1lb off on that bike that weighs over 500lbs. So you will not feel any different removing it, but if you just want to do it just for the sake of it then go for it.
But you did give me an idea for me to remove mine so Im going to hijack your thread and report back in a few days.
Old Apr 30, 2018 | 08:40 PM
JustDave13's Avatar
JustDave13
Originally Posted by Sarsippius
I think it would only need a fuel tank pressure sensor to monitor the decay rate of the vacuum pulled on the system or the pressure built up in it. I wonder if it still measures the purge solenoid circuit to see if it actually activated when commanded on.
Originally Posted by harleycharlie1992
It will monitor the amp draw of the purge solenoid, or resistance of the solenoid.
Looked at the wiring diagram for '15, only has a evap solenoid. I can't tell what ecu is reading, amp draw of solenoid, or resistance of it. Based on Mattbastards post, must be reading ohms. If you remove canister, and solenoid, install the resistor. On my 09 roadglide, It doesn't show at all, and I just left it. Doesn't hurt anything unless is visibly objective. According to schematic, there is no pressure sensor for tank pressure, which is monitored on autos
Well on automobiles the ecu also checks for a change in intake manifold pressure, I'm not sure on these bikes but with some cars the ecu looks for the purge valve, commands it open and then checks for the MAP sensor value change.
This tells the ecm that the evap is working.
what a person can do is unplug the evap hose, cap the intake port and ride the bike. If the CEL comes on then we know the ecm monitors evap performance
if monitoring the presence of the purge value is of concern the ecm looks for the coil resistance, if the value is outside what the ecm expects it should throw a CEL.
just my $00.02
Old Apr 30, 2018 | 09:02 PM
Sarsippius's Avatar
Sarsippius
Thanks a lot. Great info. The solenoid is tucked away, so not visibly offensive. I think I’ll remove the canister as well as the lines running to it and leave the solenoid plugged in and in place.
Old Apr 30, 2018 | 09:08 PM
Sarsippius's Avatar
Sarsippius
The only reason I’m looking to delete it is because on the 2011 CVO Convertible they mounted the EVAP canister on the backside of the inner primary cover (in the space between the cover and the motor). Neither Harley or the aftermarket make a chrome inner primary that has the necessary mounting holes so my options, if I want to use the chrome inner which I do, is to eliminate it or rig something up using 2 sided tape, foam, etc.
visually you cant even see it and performance wise there is zero gains to be had.
Old Apr 30, 2018 | 09:12 PM
Sarsippius's Avatar
Sarsippius
just my $00.02
If the bike was running I would definitely unplug it and see what happened but I didn5 realize there was a canister bolted to the backside of the cover until I had the entire primary removed. The bikes crippled until I decide to either eliminate it and go with the chrome inner or reinstall the OE granite primary.
Old Apr 30, 2018 | 09:14 PM
Sarsippius's Avatar
Sarsippius
I take it yours is mounted to the down tubes and not buried behind the primary. That would be a hell of a lot of work just to remove the canister LOL
Old Apr 30, 2018 | 09:43 PM
vizcarmb's Avatar
vizcarmb
The EVAP canister on 2015 touring models are under the seat next to the ECM. It would take me a 1 or 2 hours to remove all of the lines. The purge solenoid sits in the same area. Im not sure if it is even worth doing it. Maybe do it during the weekend.
http://partsfinder.onlinemicrofiche....(CALIF.%20ONLY)
If you think it's worth the time go for it.
Old Apr 30, 2018 | 10:36 PM
Highwaymans's Avatar
Highwaymans
Remove it all...... Leave the purge solenoid connected to the ecm otherwise youll get a check engine light. Done to both of mine. I run a thundermax tuner on them and removed the solenoid also..... But stock, youll need to leave the solenoid connected.... Otherwise the ecm has no idea you pulled everything else off.
Old Apr 30, 2018 | 10:59 PM
NORTY FLATZ's Avatar
NORTY FLATZ
With respect to emissions equipment, I can't see a huge difference whether it's a Softie, or Dyna, or bagger. They all share the same engine, pretty much.
Pulling the canister, won't that leave some vacuum lines open? Or, do you connect them to the A/C backing plate?
What is the purpose on removing the canister?
Unsightly? I get that.
Performance increase? Hmmm...
Will it "breathe" gas fumes via the tank vent?
