no power increase, just the sight thing. Plug the line leading to the manifold
Originally Posted by Sarsippius
Thanks a lot. Great info. The solenoid is tucked away, so not visibly offensive. I think Ill remove the canister as well as the lines running to it and leave the solenoid plugged in and in place.
best way to do it, I'd say
With respect to emissions equipment, I can't see a huge difference whether it's a Softie, or Dyna, or bagger. They all share the same engine, pretty much.
Pulling the canister, won't that leave some vacuum lines open? Or, do you connect them to the A/C backing plate?
What is the purpose on removing the canister?
Unsightly? I get that.
Performance increase? Hmmm...
Will it "breathe" gas fumes via the tank vent?
The purpose, for me at least, is that they mounted the canister to the backside of the inner primary cover. No one makes a chrome inner primary cover with the appropriate mounting holes. Not Harley. Not the aftermarket. So my options are to delete the canister or not go with a chrome cover. Since I like the chrome cover AND I already purchased it....I'm going to delete the canister. If not for that, I would leave it be. No performance hit one way or the other.
I should add that the placement of the canister behind the inner primary "Seems" to be limited to CVO Softails between 2010-2012 which would also explain why no one makes a cover for it with the proper mounting holes.
