Front brake switch sticks
Old May 18, 2018 | 11:01 AM
Labrador's Avatar
Labrador
Default Front brake switch sticks
While doing my inspection before each ride, I noticed that the brake light stays on after I press the front brakes. It will release after about 5 seconds, but sometimes it does not. I have to manually push (away) the front brake lever to turn the light off. Troubleshooting it shows that the front switch is sticking. I've sprayed lubricant in the area that holds the lever to the brake reservoir and it did not help.
Because it appears that switch is integrated with the front brake fluid reservoir and piston assembly, would I need to purchase a new front brake unit or is there a rebuild kit? If I rebuild, would I then need to take it in to have the ABS system flushed? The bike is a 2014 Heritage and I've flushed the brake fluid every 2 years as part of my yearly maintenance.
Any advice?
Old May 18, 2018 | 11:10 AM
Dice21's Avatar
Dice21
Have you changed your bars? If so, the two halves of the control might not be tight enough together. If not, it could still be the same thing.
Loosen up the switch housing, and make sure it's tight against the level perch. It's a cheap thing to try before anything else.
Old May 18, 2018 | 11:14 AM
Cygnusx51's Avatar
Cygnusx51
^ That would be the first thing I’d check also (pushing the housings together).
There is a master cylinder rebuild kit also though. Opening up the lines like that, to be safe, I’d have the dealer flush and bleed because if the ABS.
Old May 18, 2018 | 11:35 AM
Campy Roadie's Avatar
Campy Roadie
It could be the caliper/pistons need cleaned.
Old May 18, 2018 | 12:07 PM
Labrador's Avatar
Labrador
Thanks for the suggestion. I did not change the bars, but I did replace the grips. It now makes sense that it probably happened then. I will try your suggestion since it is the cheapest of the solutions.
Thanks for your help
Old May 18, 2018 | 12:13 PM
back again's Avatar
back again
if you have play in the brake lever it's the switch. If you didn't have the MC housing tight you would know it. Switches are 58 at dealer unless you buy on line at one of the Dealers that discount.
Tampa Fatboy
Aug 8, 2016 02:45 PM
elmo4fun
Shovelhead
25
Aug 27, 2015 06:54 PM
carrmat
Apr 1, 2014 04:07 PM
All Aces
Mar 7, 2013 10:02 PM
kommandokenny
Nov 9, 2006 10:49 PM
