Ground wire that goes to radio
Old Jun 2, 2018 | 10:53 AM
Scarface81's Avatar
Scarface81
Stage II
Default Ground wire that goes to radio
I have a 1998 ultra classic and i went back to the stock radio, but a ground wire that comes off of the lighter needs to be hooked up and i cant figure out where it hooks up to. Does anyone have an idea?
Old Jun 2, 2018 | 12:46 PM
GRWHD's Avatar
GRWHD
Got any pictures or the plug?
BUT most plugs the ground wire is black, red is power yellow is constant power (clock, memory exc) I think blue is power antana (if you have one) the stripes and solid Same color are speaker.....
Fairly standard for most radio’s.
Question, why go with stock?
They weight a ton and perform like 1965 tech?
The new aftermarket stuff is light weight, performs better and normally takes less power (just a thought).
make sure the fuse is inline
Old Jun 2, 2018 | 12:56 PM
RANGER73's Avatar
RANGER73
WTF does the lighter ground have to do with the radio?
Old Jun 2, 2018 | 01:20 PM
Scarface81's Avatar
Scarface81
Stage II
I went back to stock because the aftermarket ones I put in keep getting wet and smoking. so I went back stock. the wire comes off the lighter plug on bottom of inner batwing, I know when it touches the radio , the radio turns on it does spark as well, but it works and sounds good. I assumed that the black wire is a ground.
that I have no idea , im not sure why it is on the lighter it is attached to the ground and when I touch the wire to the radio the radio turns on and works. I just don't know where the ground should go on the radio
Old Jun 2, 2018 | 02:08 PM
RANGER73's Avatar
RANGER73
Most radios have a threaded stud on the back or a black wire in the harness.
Old Jun 2, 2018 | 09:44 PM
Ride my Seesaw's Avatar
Ride my Seesaw
Run a wire from the chassis of the radio to the frame of your bike and be done with it. Sourcing ground from your cig adapter is not the best place, it will work but will set up current loops, frame ground is the proper way to go.
silverback17
Jul 20, 2017 09:27 AM
watindes
EVO
17
Sep 4, 2014 11:37 AM
KCwildguy
2014-2024 Touring Models
14
Jun 23, 2014 11:32 AM
CVO-RK
Audio Systems
11
Apr 22, 2013 09:26 AM
rgrecco
Mar 27, 2008 05:24 PM
