Fuse / Electrical Question
Now every time I crank Engine... Pops Fuse. So I did a manual investigation of entire new Electrical Wiring. Only issue I found was @X1 Ohms I had about 3/4 scale of meter going from Positive lead on Starter to Starter Case. Took Starter out of circuit and ran 12VDC to it, it cranks....
I was told to remove fuse from circuit (Battery to Starter Solenoid) I put it in circuit to solenoid (Starter Switch to Starter Solenoid Coil...
Should I not have a fuse in starter circuit? I had broken Bike down originally to 3 fuses (Circuits)
Gauges and light circuits and starter solenoid:
Taillight and Turn signals
Starter
I now have still 3 circuits:
Taillight and Turn Signals
Starter Solenoid
I worry about protecting Starter. Engine is totally new, including Starter. When I had Starter removed from Engine I had also taken to Shop who had built it, They said Starter Amps is okay and to remove fuse (I had used a 20 amp fuse) Maybe I should use a 40 amp Circuit Breaker??
Help!!
Starter
Starter Solenoid
Help!!
