In the old days, they would repair battery post but,
BUT, they worked with led all the time and could literally throw it on anything.
Like said if you go this route-be very carefull as a BOMB lurks there in the battery.
You could get blasted, burnt blinded or all three.
What is it worth to you?
Doesn't look like anything would be real reliable. Maybe put a copper block in the gap and run a bolt through to hold it side to side to hold it there. then drill front to back for the for a fastener bolt.Think I'd bite the bullet and buy another if the return doesn't work.
Yep new battery. Fuc ups are costly trust me I know.
Don't be using an open flame to solder a battery post. Batteries release hydrogen gas which is quite explosive. When a battery explodes it's a big deal & you risk serious injury. Be careful!
If you did that to your battery let me be the first to suggest that your skill sets may be lacking and/or you are a heavy drinker. In either case pony up for your mistake and buy a new battery and install it without shorting it out like you did that one. If you still plan to "repair" the post could you please send me your address so that I might take a couple of days and fly out and see this. I haven't seen funny **** like this in a long time. If you are lucky you will just burn the bike down, if not, the garage, house, ? I may also bring the family, I never take them anyplace good. Don't ask me how I knew you shorted it out.... Remember these words to live by: "Just because it 's a bad idea doesn't mean it won't be fun!"
Just drill a thru hole and use a SS bolt, nut and washer. The back lug and 1/2 the other lug will carry twice the arms the battery can put out. Next time, do the work..then ride the whiskey. Haaa
Well for other peoples benefit... The cable terminal is designed to sit flat on top of the post. It wasn't sitting flat but at a bit of an angle. Now I always torque everything to spec and the battery was no different. I figured the bolt would flatten the terminal onto the post. Well it didn't happen. As the bolt was tightened the terminal didn't flatten. It was easier for it to move down and sideways as torque was applied. The post split before the required torque was achieved. So! The moral of this tale is make sure the terminal is lying flat on the post before you tighten the bolt.
Thanks for the replies.
How can you suggest they warranty something that the customer screwed up?
Could have been/Could be, an issue with the alloy of the post lending it to be too soft,,
I mean for cryin-out-loud,, for $200 the battery should have installed itself!!
