repairing battery post
Is the post lead?
In the old days car dents were repaired with lead.
(Not sure if solder is lead).
So get a lead stick, a small torch, build up the post with molted lead, file to shape, tap threads and reconnect harness.
Good luck.
OP you try the solder stunt you are committed and make sure the solder in question is real lead, a lot of the stuff in hardware stores is aluminum based, won't mix, your post will melt off first. Secondly you will damage the case and the heat transfer to the internals is not good for the battery. You can make it work but for how long?
Most of common solder is also non-lead,, yet made of alloys that freely and easily bond with the current electrical connections used not only in the battery market but typical current vehicle wiring.
There is no need to purchase "lead".
The simple process of solder tinning of the components will determine if adhesion is going to occur or if a flux will be needed to assist.
Since when is "Open Flame" needed to solder.
I would have been able to have that terminal/cable connection repaired and installed on the bike in a permanent and reliable manner in a matter of minutes (not hours) with common tools in the garage..
My point for you was it does nobody good when a speculation is offered when rampant with mis-information or total lack of knowledge.
If you just want to up your post count,, why not go back to the new members section and greet people?
Attachment 594741
There are other manufactures like the battery that the OP shows that use a threaded block that fits inside the Void of that Perimeter Terminal
I buggered the post on my battery and am looking for opinions on where to go from here. I've been advised that it can be repaired by building up the post with solder. If I go that way I'll place a bolt and nut into the post and melt the solder around them. Whadya think??? good idea or bad. It's a new $200 battery so I don't want to buy another if I can repair it.
Try this out: Call up the manufacturer and ask if they can Recase the battery. Many of them will do this for a very small fee and your problem will be solved.
My $ 0.02 of course....
Good.luck on whatever you do and let us know results.
