Much of an engine's wear comes from cold start-up - those first few seconds (or minutes) where lubrication is not optimal ... in some cases, for a short bit, not lubricating!
I expensive commercial applications there are pre and post lubers where oil (often pre-warmed) is pumped through the engine before start-up; post lubing is generally for providing oil tot he turbocharger(s) after shutdown because they continue to spin at high RPM and benefit from post shut down lubrication.
I said all of that to say this: the more strain or duty cycle (revs) you put on am engine int he first moments after cold start-up, the worse it is for that engine.
This video, particularly at 3:09 where neither rocker arm is getting much (if any) oil even though the oil is 175F degrees! The S&S rep even states (at about 3:10) that the illustration shows why you should not rev your engine right after start-up.
As an unrelated aside, I believe that the video "demonstration" is skewed because a harley's oil system pumps oil tot he rear cylinder first. I wonder how the "demonstration" would have gone had they installed the S&S tappets int he front cylinder and the Chevy tappets in the rear ???
Either way, the video clearly demonstrated why you should not rev your engine right after start-up ... even with hot oil!
Shovels oil differently if I remember correctly.....Big if.
Alum cylinders need to come up to speed B4 romped on, or oil leaks will occur.
Esp true with Evo alum cylinders
Are we talking about engines or motors here? I am pretty sure a quick rev, some call it a blip, won't hurt a motor. That's not to say it's going to hurt an engine.
Please explain the difference between an engine and a motor...
