Kill switch question
Old Jun 30, 2007 | 10:46 PM
Sam's Avatar
Sam
Default RE: Kill switch question
ORIGINAL: YUCK
Sam,,,,not that I have a kill switch,,,I'm just curryass,,,and killing time....Y
ORIGINAL: Sam
ORIGINAL: floydpink
I feel a little dumb asking this but since a mechanic said it, I am somewhat curious;
While having some electrical work done, I was chatting with the service guy who was saying to never shut off the kill switch on the handlebars as this is the first component to break normally. He said to keep it always on and only shut off on the tank switch. I am not sure if I believe him and also have a warranty to cover it in the event he is correct.
Well I've been selling Harley's for over 20 years and the only only adviceI can give you, is.........find a new mechanic
[sm=icon_rofl.gif][sm=icon_rofl.gif]
.................Damn that bike of yours looks good Yuck
Old Jun 30, 2007 | 10:54 PM
YUCK's Avatar
YUCK
Thanks Sam,,,its a work in progress....
Educate me in this kill switch theory so I can sleep tonight [&o]
Old Jul 1, 2007 | 02:05 AM
Guilty's Avatar
Guilty
The kill switch on Harley's was designed so that you can know how itfeels to be adumbass when you accidently hit it instead of the turn signal...?
Old Jul 1, 2007 | 02:37 AM
RandyNC's Avatar
RandyNC
I believe that the kill switch was originaly enforced by OSHA. Got to have those safety buttons to be safe in case your hand slips off the clutch...i'm sure you can think up many reasons the kill switch could be used...also it's handy when you park sometimes just being able to keep both hands on thehandlebars anduse the killswitch. I use mine most of the time, just have to remember to cut the main switch off so your lights won't stay on. What ever you like or get use to using.
I don't think there really is a right or wrong way to turn your bike off.Ü
Old Jul 1, 2007 | 07:05 AM
Demkay's Avatar
Demkay
I do what the manual tells me....... kill the engine with the kill switch, then kill the Power on the tank.
Old Jul 1, 2007 | 08:49 AM
tplyons's Avatar
tplyons
Just get a Sporty, you HAVE to use the killswitch. No tank mounted switch.
Old Jul 1, 2007 | 08:59 AM
ditch_dgr's Avatar
ditch_dgr
ORIGINAL: pococj
To turn the ignition power completely off, use the key switch. I can think of at least one reason for this sequence; thekill switch is designed to break the current flow with minimal damage to the contacts, while the key switch design doesn't protect the contacts from the arcing as it breaks.
I had always heard the same thing, the kill switch is desgned for this purpose the tank switch is not.
Old Jul 1, 2007 | 09:15 AM
GrayRider's Avatar
GrayRider
I believe the reason for using the handlebar switch first, is that it allows the computer to reset.
Old Jul 1, 2007 | 09:35 AM
Edmo's Avatar
Edmo
I use my kill switch to alert me if I'm in gear during start...
I normally park on flat ground and leave the bike in neutral. I then use the tank switch to shut it down.
When I do park on an incline and leave it in gear, I use the kill switch. Since I only usethe kill switchwhen I shut down when in gear, it isnow a simple reminder that a normal habit pattern was changed.
Edmo
Old Jul 1, 2007 | 09:37 AM
1flhtk4me's Avatar
1flhtk4me
I think the kill switch is only located for convenience/emergency.I rarely us it.
