First Winter
If I recently changed the oil, could I just fill the tank and add fuel stabilizer and run the bike for about 20 minutes or so and bring it in the house for the winter?
No bike lift , so just roll it every so often to keep from sitting in same spot ?
Fill tank, add Stabil, run engine five minutes to get Stabil into carb / FI.
Plug in battery tender or pull battery and place in basement.
No problems in 50 years.
The experts will be along soon to tell you the right way to do it...
to keep in the system long term (over the winter is long term), sta-bil or not. Heard lots of horror stories about bikes stored
with ethanol gas over the winter. DON'T. Fill the tank full of non-ethanol premium, put in sta-bil, run it a bit, you're golden.
I also make sure there are plenty of sticky mouse traps around the bike. Mice love to crawl up under the bike cover and
chew on the seats. Not good. The sticky traps help keep them off.
A friend of mine swears by removing the spark plugs, spraying in some fogging oil, then replacing the plugs right before
storing (don't run the bike afterwards). It helps protect the cylinder walls and piston tops from condensation and
oxidation.
Also have DCon along the walls...
